Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-19-2010, 12:26 PM   #1
carrier weather maker won't stay lit
I'll start with the startup process. First of all the blower is always on high, I push the reset button turn the thermostat and the gas knob on. The inducer starts turning and about 10-15 seconds after that the blower turns off. The HSI starts glowing red and then the gas relay is tripped by the controal unit and the burners turn on, about 65 seconds of the burner being on the blower starts back up and about 10-15 seconds after that the burners shut off and the blower is stuck on. if i turn the thermostat blower position to off it keeps going. I tried moving the sensor out of the way of the flame and the burners only stay on for about 3 seconds. I initiated the self test feature and I herd all the relays on the controal unit turn on and off with the accompanying devices when applicable. Why won't my bruners stay on and why won't the blower turn off, I have a feeling the two problems are related.
Thanks in advance
Nick
NDELEON is offline   Reply With Quote
Old 10-19-2010, 01:12 PM   #2
HVAC / Plumbing
this needs to be in the HVAC section. Do you have flashing LED on the control board ? If so, count flashes & look up the code. Sounds like flame failure is the reason burners won't stay on
kenmac is offline   Reply With Quote
Old 10-19-2010, 01:24 PM   #3
I'll repost in HVAC thank you and no there is no flashing led on the controal board
Weather Maker 9200 Furnace benoy HVAC 5 12-07-2009 09:03 PM
Carrier Weather Maker inducer voltages used2beatech HVAC 16 10-16-2009 03:43 AM
Carrier weather maker 9200 furnace NO 24 volts mmtuxedo HVAC 1 09-25-2009 07:49 PM
Carrier won't stay lit kurto HVAC 10 12-13-2008 02:50 PM
Carrier Weather Maker not turning on rickvj HVAC 5 10-25-2007 01:46 PM
