Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-19-2010, 09:24 PM   #1
Can you tell me about this Nordyne furnace?
I moved here 5 years ago. The house was built in 1984. The furnace is a Nordyne 90+ AFUE (I think).
I need to know how old it is and if it is considered efficiant by todays standards.
I just spend $300 to have a pressure switch replaced. 2 years ago I had trouble with condensed water backing up into the exhaust motor...about $400 before we got the trouble stopped for good.
sofasurfer is offline   Reply With Quote
Old 12-20-2010, 01:10 AM   #2
Persona Non Grata
VIPlumber's Avatar
The model # & serial # should be on the inside of the access panel, which you can use when you call Nordyne to find out what year & month it was made. I couldn't find anything on the web telling me how to decipher their numbering system.
While I don't know anything about Nordyne personally, if it is a 90+ as you believe, that tells me that it's 90% efficient, which is pretty good.
The only other recommendation I can make is to have regular servicing, which should keep it operating at peak efficiency.
VIPlumber is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Nordyne G6TL Furnace Question kentcasey HVAC 4 01-28-2009 11:14 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
