Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-11-2011, 12:25 PM   #1
Can I remove wire arm from icemaker
I just installed a replacement Whirlpool icemaker in my Kenmore Elite side by side and it works great, except it has the wire on and off lever on it and my fridge is for the optic on and off. I tried just removing the arm but that wouldn't make the icemaker work so I had to put it back on. Is there anyway I can use this model icemaker for this optic system of the refrigerator?
Thanks so very much for any info. boandbob
boandbob is offline   Reply With Quote
Old 12-11-2011, 01:12 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
no, why didn't you just install the correct icemaker?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 12-11-2011, 02:17 PM   #3
I bought the one that Sears said was the Whirlpool replacement ice maker. Thats why I am hoping that there is some adjustment etc that can turn off the wire arm and allow just the optic part to work.
Old 12-12-2011, 06:01 AM   #4
You got the wrong i/m-as Hw/man pointed out. if you have to keep that i/m you'll have to take off that arm and swap the stripper board..or just swap the new module onto the old i/m [unless the mold is flaking]. correct # for optic model [8 cube] is-W10122502
Jacques is offline   Reply With Quote
Old 12-12-2011, 06:04 AM   #5
P/S-if you take the arm off-remove it while it's in the down position [on].
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 09:20 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
