#1 |
Can I combine one outlet Surge Protector with a 6-outlet power strip
Hello all,
I plan to buy this product Tripp Lite SPIKECUBE Surge Protector Wallmount Direct Plug In 120V 1 Outlet 600 Joulehttp://www.amazon.com/Tripp-Lite-SPIKECUBE-Protector-Wallmount/dp/B00006B81E/ref=cm_cr_pr_product_top Since it has only one outlet and I want to know whether I can combine it with the 6-Outlet Power Strip http://www.staples.com/Fellowes-6-Ou...product_387477 In this way, it can protect LCD monitors/PC/printers at the same time. Q> Does it work? or I can only plug in one appliance for each surge protector? Thank you |
#2 |
Average Joe/ex-Navy IC3
Yes, it would not hurt, but also keep in mind, that you need to not use a Surge with a UPS.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#3 |
[QUOTE=gregzoll;1139950that you need to not use a Surge with a UPS.[/QUOTE]
why? it is because that UPS already has such a function? |
#4 |
That would be correct.
| Display Modes | |
| TV power bridge into existing outlet and protected by an external surge protector | andytran73 | Electrical | 4 | 12-14-2011 09:00 AM |
| Odd voltages at outlet | TJF | Electrical | 12 | 11-01-2011 10:13 PM |
| Power consumption in a power strip. | AC230V50Hz | Electrical | 11 | 06-06-2011 08:55 AM |
| Wiring a switch, power from outlet | Big Bill | Electrical | 4 | 09-15-2007 04:59 PM |
| Outlet and light pigtailed to power. ok? | skellies | Electrical | 2 | 06-24-2006 02:08 PM |
