Can I combine one outlet Surge Protector with a 6-outlet power strip
Hello all,
I plan to buy this product Tripp Lite SPIKECUBE Surge Protector Wallmount Direct Plug In 120V 1 Outlet 600 Joulehttp://www.amazon.com/Tripp-Lite-SPIKECUBE-Protector-Wallmount/dp/B00006B81E/ref=cm_cr_pr_product_top Since it has only one outlet and I want to know whether I can combine it with the 6-Outlet Power Strip http://www.staples.com/Fellowes-6-Ou...product_387477 In this way, it can protect LCD monitors/PC/printers at the same time. Q> Does it work? or I can only plug in one appliance for each surge protector? Thank you |
Yes, it would not hurt, but also keep in mind, that you need to not use a Surge with a UPS.
[QUOTE=gregzoll;1139950that you need to not use a Surge with a UPS.[/QUOTE]
why? it is because that UPS already has such a function? |
That would be correct.
| All times are GMT -4. The time now is 12:25 AM. |
