Can Electronic Oven Thermo Be Calibrated - Appliances - DIY Chatroom Home Improvement Forum
Old 11-26-2011, 01:36 PM   #1
can electronic oven thermo be calibrated
as stated im curious if an glass cooktop stove can have the oven thermostat calibrated? or is it gonna need the whole control. Its all digital,and i belive its a kenmore,if it need the whole board anyone have a ballpark guess as to the cost for parts. and any reason someone with 30 years of hvac experiance couldnt make this repair. thanks you guys!!!
kennzz05 is offline   Reply With Quote
Old 11-26-2011, 08:02 PM   #2
bump to the top
Old 11-28-2011, 06:00 AM   #3
30yrs hvac=be simple for you. the instructions for resetting temp +/- 35* are in your owners guide...check the sensor from rear should read 1080 ohms at 70* [positve heat coeffecient].
Jacques is offline   Reply With Quote
Old 11-28-2011, 07:50 AM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
take your temp reading then decide where to start, like Jacques said you have a built in + - 35 degrees built into control board. If its more than that you may need sensor or board
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 12-02-2011, 02:17 AM   #5
not sure if i have the manual? truck driver and im not home,(mother in law says its inaccurate per external oven thermo) is it done by going into some type of programming mode on the switch itself or do i have to open it up. can someone direct me to a site where id be likely to find a manual? thanks guys!!!
Old 12-02-2011, 09:44 AM   #6
Go to manf web site and look up use and care manual using your complete model # [taken from nameplate].
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Roper Electric Oven Range Problem mcnutty Appliances 6 07-05-2011 05:32 PM
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 10:37 PM
Gas oven problems gregsmy Appliances 1 12-03-2009 05:55 AM
