Can An ELECTRIC Range Be Installed So It Touches A Wall? - Appliances - DIY Chatroom Home Improvement Forum
Old 05-27-2013, 10:42 PM   #1
Can an ELECTRIC range be installed so it touches a wall?
Iím going to buy a new electric range. My current one was installed in 1986, and has probably reached the end of its life.
The current unit is about 1.5 inches from the wall. The front of it is currently flush with the cabinets, so I was wondering if that was done for aesthetics or if it was installed with a gap between the wall and the back of the range because of a code / safety reason.
It doesnít appear that it was kept from the wall to provide room for the plug, because there is plenty of room behind the bottom drawer to allow the cord to be plugged in safely.
The front of the new model Iím considering will be flush with the cabinets if I push it all the way to the back wall. Is it safe to do that, as long as there is clearance at the bottom to plug it in, or do I need to keep it a certain distance from the wall?
Arnold Ziffel is offline   Reply With Quote
Old 05-28-2013, 12:20 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,598
no worrys, it can install flush with wall if need be
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is online now   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
Arnold Ziffel (05-28-2013)
Old 05-28-2013, 05:15 PM   #3
FClef's Avatar
Rewards Points: 160
The installation manual will tell you everything you need to know about installing the range safely. It will even tell you things you didn't need to know like don't lick the burners to see if they are hot.
FClef is offline   Reply With Quote
Replacing a 30" Electric Drop-in Range SLC3271 Appliances 5 06-10-2014 10:22 PM
Converting electric range to dual-fuel? jmklump Appliances 6 12-28-2011 12:25 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Electric Range Wiring manhattan42 Electrical 11 07-05-2006 06:03 PM
