Can 240V Kettle Be Used In N. Am 115V ? - Appliances - DIY Chatroom Home Improvement Forum
Old 01-15-2013, 09:48 AM   #1
Rewards Points: 93
Can 240V kettle be used in N. Am 115V ?
Looking at purchasing a unit that heats water with the usual immersed coil-thingy, but it is designed to be used in the Middle East on 240 V service. Seller says it has been used in the U.S. with an adapter.
Does such and adapter really exist? I can't imagine it would permit full heating power. Adapters surely work the other way around...permitting 115V appliances to be usde on stepped down on 240V service?
Thanks.
Hossenfeffer is offline   Reply With Quote
Old 01-15-2013, 10:51 AM   #2
Rewards Points: 744
There are adapters, though it will likely take twice as long to heat the water.
Seattle2k is offline   Reply With Quote
Old 01-15-2013, 11:51 AM   #3
i would check with the manufacturer and see if 115 volt heating element is available for the unit. pictures would help. why not run it on 240?
Old 01-15-2013, 11:53 AM   #4
Rewards Points: 13,458
Or run a new dedacated line and breaker to run just that.
Old 01-15-2013, 08:00 PM   #5
Rewards Points: 962
4X. P=V**2/R
I needed space in my panel box, so I ran a 240 baseboard heater on 120v. It got warm, which was all I needed.
I am sure there are step up transformers available, but they would cost more than a 120v kettle and probably require more than a 20a outlet.
Toller is online now   Reply With Quote
Old 01-16-2013, 07:37 AM   #6
DIY staff
Rewards Points: 7,174
Why buy one that doesn't work without jury rigging it?
Look for one that is already wired for 110---
Am I missing something here?
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
DexterII (01-16-2013), joecaption (01-16-2013)
Old 01-16-2013, 08:43 AM   #7
I do not think your missing anything, it just sounds like someone who does not how these work and how bad an idea it is.
If the O/P could tell us what there really trying to do with this thing I'm sure someone could come up with a better safe way to do it.
Old 01-16-2013, 08:58 AM   #8
Haverhill Trade 1965
I had a 240v compressor that I had to find power for on jobs. I had a short extension cord adapter that went to dryer or electric stove outlet.
Duckweather is offline   Reply With Quote
Old 01-16-2013, 09:12 AM   #9
Just read that again. You have to check one other thing. Many countries use a different cycle too. I know Germany used to use 50 cycle 220 volt.
Old 01-16-2013, 02:02 PM   #10
Rewards Points: 1,294
It is also most likely a single wire 240 unit and not a 2 wire 240 like we are accustomed to here in the states
danpik is offline   Reply With Quote
Old 01-17-2013, 07:03 AM   #11
Also check to see if there is a switch that says 120 / 240 on it somewhere
Old 01-17-2013, 08:04 AM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
A heating device designed to work on 220-240 will only use 25% power when connected to 120 volts. It will take forever to heat.
Coastal South Carolina
115v AC marine a/c help with wiring diagram prostock3 Electrical 15 08-08-2011 03:16 PM
Power 120V Pump from a 240V circuit RoberTX Electrical 26 07-05-2011 11:43 PM
240v questions.... ITSANSS Electrical 16 05-11-2011 05:40 PM
Replacing 240V Wall Heater with 240V Base Board Heater jasoncw Electrical 7 11-26-2010 10:39 AM
Do you think a tool running at 240v works better than at 120v? Piedmont Electrical 39 07-03-2009 09:50 PM
