-   -   Can 240V kettle be used in N. Am 115V ? (http://www.diychatroom.com/f47/can-240v-kettle-used-n-am-115v-169184/)
Hossenfeffer 01-15-2013 09:48 AM
Looking at purchasing a unit that heats water with the usual immersed coil-thingy, but it is designed to be used in the Middle East on 240 V service. Seller says it has been used in the U.S. with an adapter.
Does such and adapter really exist? I can't imagine it would permit full heating power. Adapters surely work the other way around...permitting 115V appliances to be usde on stepped down on 240V service?
Thanks.
Seattle2k 01-15-2013 10:51 AM
There are adapters, though it will likely take twice as long to heat the water.
DannyT 01-15-2013 11:51 AM
i would check with the manufacturer and see if 115 volt heating element is available for the unit. pictures would help. why not run it on 240?
joecaption 01-15-2013 11:53 AM
Or run a new dedacated line and breaker to run just that.
Toller 01-15-2013 08:00 PM
4X. P=V**2/R
I needed space in my panel box, so I ran a 240 baseboard heater on 120v. It got warm, which was all I needed.
I am sure there are step up transformers available, but they would cost more than a 120v kettle and probably require more than a 20a outlet.
oh'mike 01-16-2013 07:37 AM
Why buy one that doesn't work without jury rigging it?
Look for one that is already wired for 110---
Am I missing something here?
joecaption 01-16-2013 08:43 AM
I do not think your missing anything, it just sounds like someone who does not how these work and how bad an idea it is.
If the O/P could tell us what there really trying to do with this thing I'm sure someone could come up with a better safe way to do it.
Duckweather 01-16-2013 08:58 AM
I had a 240v compressor that I had to find power for on jobs. I had a short extension cord adapter that went to dryer or electric stove outlet.
Duckweather 01-16-2013 09:12 AM
Just read that again. You have to check one other thing. Many countries use a different cycle too. I know Germany used to use 50 cycle 220 volt.
danpik 01-16-2013 02:02 PM
It is also most likely a single wire 240 unit and not a 2 wire 240 like we are accustomed to here in the states
Duckweather 01-17-2013 07:03 AM
Also check to see if there is a switch that says 120 / 240 on it somewhere
rjniles 01-17-2013 08:04 AM
A heating device designed to work on 220-240 will only use 25% power when connected to 120 volts. It will take forever to heat.
