Calibrating A Fridge/freezer Thermostat - Appliances - DIY Chatroom Home Improvement Forum
Old 08-13-2013, 07:25 PM   #1
Rewards Points: 22
Calibrating a fridge/freezer thermostat
We had a service technician come out to our house and he told us that the thermostat was broken and needed to be replaced. The part is $29.00. They want to charge me $300 to fix it. The tech was nice and told my wife that I need to calibrate the thermostat when I get it. All of my research shows that these things come from the factory pre-set. Anyone ever had to do this before? I a going to hop on the "google machine" and see what I can find but you guys/gals are always so helpful so I figured I would ask here.
Thanks!
johnnybeltway is offline   Reply With Quote
Old 08-13-2013, 07:31 PM   #2
Rewards Points: 13,446
Posting the make and model may get some answers.
Old 08-13-2013, 08:07 PM   #3
Rewards Points: 22
Calibrating a fridge/freezer thermostat-image-276419879.jpg
Good point. It is a kenmore model 529.72913200 bottom freezer. Pic of label attached.
Old 08-13-2013, 08:24 PM   #4
Rewards Points: 6,652
What the tech means, is give them a cold drink after they get done installing it, and it is recalibrated. BTW, your part number you posted is incorrect, the first part is as on the label 596.
There are three parts that it could be. 1) Defrost Thermostat, 2) Temp. Control Thermostat, or 3) Damper Control Assembly. http://www.repairclinic.com/Kenmore-...ermostat-Parts
None of them involve "Recalibrating". It is remove the old part, install the new part, plug back in and you are done. The tech is an idiot and thinking that they can pull one over on a customer. That thermostat unit is pretty much universal between Amana, Whirlpool, Cornelius & Scotsman makes a version of it.
That unit was made by Amana. You can get the part on amazon.com, beware that the parts on ebay.com are out of old units, and come with no warranty. See regarding how to replace the thermostat.
The Following User Says Thank You to gregzoll For This Useful Post:
johnnybeltway (08-13-2013)
Old 08-14-2013, 12:33 PM   #5
Rewards Points: 22
Part Ordered! Thanks for all your help folks!
The Following User Says Thank You to johnnybeltway For This Useful Post:
gregzoll (08-14-2013)
Old 08-20-2013, 10:44 AM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
I suspect he told you that to scare you away from doing your own repairs. There is no reason to ever calibrate a new thermostat.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
I need help wiring my thermostat. batalbj1 HVAC 3 03-28-2013 10:30 PM
Thermostat Replacement kgreen4me Electrical 2 01-27-2013 11:46 AM
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 10:53 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
