Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-10-2009, 02:28 AM   #1
Question
Bypassing PCB on window A/C unit
Hi all,
I have a window A/C unit that I've bypassed the PCB on, while keeping the capacitor in the circuit, so that the unit will turn the compressor and fan on full blast when it receives power (it's a digital unit that normally doesn't turn on until you press the on button, even when power is going to it). The reason I'm doing this is to create an insulated cold room that is monitored by an external thermostat that will pass electricity on to the A/C unit once a high-temperature threshold event is reached.
My question is, how big of a risk does thermal issues with the compressor, etc hold with this setup? The chamber it's cooling is only 4' x 7' x 2', so it's not that big, and the unit will only be on maybe 5 minutes per hour (the chamber is insulated with 2" foam). Only reason I ask is because I'm told that thermal meltdown issues are introduced when bypassing the PCB, as the sensors for that are no longer being used. *shrug*
howejustin is offline   Reply With Quote
More On This Topic
Hello! This is Ross on behalf of expertvillage.com. Capacitors store electrons they are like a battery and they hold a charge and release it later. Capacitors composed of two conductors separated by an insulator, no it is dielectric. Now you've heard of... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. What we are talking about here is we are talking about the envelope of your house. Think of... Read More »
Hi, my name is Mark Delgado with American Auto Service for Expert Village. So we have the compressor that compressed the refrigerant to a high pressure gas that went through the line. Now it goes through the condenser. In this condensor unit, it's like a... Read More »
Ham radio has just a few truly essential components, one of them being the antenna. If you're a ham working multiple bandwidths but have limited space, you can use HF traps, which are combinations of resonant parallel coils and capacitors. Traps... Read More »
Hi, my name is Mark Delgado with American Auto Service for Expert Village. Another easy indication of a bad compressor is that it is going to be noisy. It may rattle which may mean that it is low on oil or that it may be worn. This has a lot of moving... Read More »
Need help w/squealing screeching ac window unit ohiogirl HVAC 1 07-12-2009 08:01 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 07:11 PM
Portable A/C unit + Swinging Window alpha202ej HVAC 1 07-18-2008 12:51 PM
Adding Geothermal heat exchanger to window unit richinok HVAC 4 06-23-2008 08:59 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
