Buzzing Refrigerator - Appliances - DIY Chatroom Home Improvement Forum
Old 04-25-2011, 02:23 PM   #1
Buzzing refrigerator
title says it all. Our fridge does this buzzing sound every now and then. Seems to be when the engine turns or or a fan or something of the sort. If we push on the door, it stops (for the time we are holding it).
I think it could be that it is not levelled. Would that make sense? Is this something can be fixed easily?
BandE is offline   Reply With Quote
Old 04-25-2011, 08:44 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
why don't you level it and find out?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 04-25-2011, 09:05 PM   #3
Rewards Points: 148
And while you are at it, roll it away from the wall, unlug it, and vacuum underneath it, including all of the nasty dustballs clinging to the components. Some of what you will see is insulation, and you don't want to disturb the electical or refrigeration components, so be careful, but unless you have cleaned under there in the past year, you will probably be surprised at the filth that you will find. Not that it is likely to be causing the buzzing, but it only makes sense as long as you are down there leveling it, as hardwareman suggested.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
Water line for new refrigerator? pa555 Plumbing 5 06-08-2012 06:06 PM
GE refrigerator not cooling rjniles Appliances 1 06-01-2008 07:21 PM
4th of July Refrigerator DavePA Electrical 4 03-18-2008 09:16 AM
