Buzzing/Humming Countertop Range - Appliances - DIY Chatroom Home Improvement Forum
Old 12-03-2008, 10:10 PM   #1
Rewards Points: 33
I noticed a hum coming from my old electric countertop drop-in range. Its very faint and I wasnt sure where it was coming from until I threw the breaker and checked for the noise. To clarify, this noise is happening when all of the "burners" are off. Its not really a nusiance because its barely noticeable, but I wanted to ask around and find out:
1. Why it might be making any noise at all
2. Is this a safety concern?
I checked to make sure it wasnt the fan or light from the hood, the hum is definitely coming from the range.
Ive been planning on replacing it when it became more convenient, but if I find out it might be getting ready to start my house on fire I'll have it pulled out of there tonight.
Any ideas?
JRoot is offline   Reply With Quote
Old 12-04-2008, 10:09 AM   #2
Does it have an older style analog clock? they use a synchronous motor and can hum.
hychesee is offline   Reply With Quote
Old 12-04-2008, 10:39 AM   #3
bofusmosby's Avatar
You may have a humdinger trapped inside.... Sorry, just joking around.
The clock idea could be the case. I had an old stove years ago, that the clock DID hum at times. If not, well, you might want to have someone take a look at it. You can't be too careful.
bofusmosby is offline   Reply With Quote
Old 12-04-2008, 10:51 AM   #4
Last the summer I had a bird come down my 20' foot chimney and navigate 6' of stove pipe into my wood stove, it didn't hum and sounded more like a baseball being thrown around in there. Good thing I forgot to close the damper otherwise it would of died in the flue, I opened all the doors and the little "blackbird" found its way out.
Old 12-04-2008, 12:19 PM   #5
Rewards Points: 33
There is no clock. I know the kind you are talking about though, my parents have one. Doesnt sound like the hum is a big concern??
Old 12-04-2008, 12:31 PM   #6
OK so there are no lights, clock, or timer built in to the range, is it a self cleaning or convection model? and how old would you say it is.
Old 12-04-2008, 12:35 PM   #7
Rewards Points: 33
I'd say 15-20 yrs old. There are 4 burners and 4 control knobs. Its not self cleaning, and is totally idependent of the oven unit. The only way I can get the humming to stop is by throwing the breaker. I have turned all of the burners on and off to se if it would affect the hum and it doesnt....
Old 12-04-2008, 11:49 PM   #8
Rewards Points: 530
That is strange. From what you describe, I would throw the breaker off and disconnect the wires at the terminals on the infinite switchs one switch at a timet hen turn the breaker back on and see if I could locate the problem, but I have some experience with the infinite switchs and the wiring. You could kill the power just to be safe and disconnect the wires at the elements. No change of getting them crossed that way as long as you put the same two back on the same element.
Btw, the infinite switches I speak of are the temp switchs that operate the individual elements.
I don't think I would let it sit there with power on while it is humming or leave it unattended. Either throw the breaker or pull the plug from the wall.
P.S. With power off, check the connections on the back of the range where the power comes in. Make sure all connections are tight there and at the elements. Wouldn't hurt to also check for tight connections on the switchs too.
Old 12-05-2008, 06:42 AM   #9
Rewards Points: 33
Thanks, I think I'll take your approach on this boman and disconnect each infinite switch one at a time. Taking a closer look at it, three of the switches have identical knobs, and the 4th is different, maybe a replacement. This will be the first one I check out.
Im still curious what could make a switch hum like that - if it is in fact the switch making the noise.
Thnks for the help so far everyone.
range hood through the wall - - -stud in the way pacifier1er Building & Construction 30 05-21-2013 09:23 AM
Gas Range cookiemom1970 Plumbing 1 11-14-2008 04:58 PM
New countertop, sink and faucet darlenep Project Showcase 4 08-17-2008 09:33 PM
3 prong range? laduehelp Electrical 39 03-11-2008 01:33 PM
gas range swap kenny11876 Appliances 2 02-20-2008 08:31 PM
