-   -   Buzzing/Humming Countertop Range (http://www.diychatroom.com/f47/buzzing-humming-countertop-range-33119/)
JRoot 12-03-2008 10:10 PM
I noticed a hum coming from my old electric countertop drop-in range. Its very faint and I wasnt sure where it was coming from until I threw the breaker and checked for the noise. To clarify, this noise is happening when all of the "burners" are off. Its not really a nusiance because its barely noticeable, but I wanted to ask around and find out:
1. Why it might be making any noise at all
2. Is this a safety concern?
I checked to make sure it wasnt the fan or light from the hood, the hum is definitely coming from the range.
Ive been planning on replacing it when it became more convenient, but if I find out it might be getting ready to start my house on fire I'll have it pulled out of there tonight.
Any ideas?
hychesee 12-04-2008 10:09 AM
Does it have an older style analog clock? they use a synchronous motor and can hum.
bofusmosby 12-04-2008 10:39 AM
You may have a humdinger trapped inside....:laughing: Sorry, just joking around.
The clock idea could be the case. I had an old stove years ago, that the clock DID hum at times. If not, well, you might want to have someone take a look at it. You can't be too careful.
hychesee 12-04-2008 10:51 AM
Last the summer I had a bird come down my 20' foot chimney and navigate 6' of stove pipe into my wood stove, it didn't hum and sounded more like a baseball being thrown around in there. Good thing I forgot to close the damper otherwise it would of died in the flue, I opened all the doors and the little "blackbird" found its way out.
JRoot 12-04-2008 12:19 PM
There is no clock. I know the kind you are talking about though, my parents have one. Doesnt sound like the hum is a big concern??
hychesee 12-04-2008 12:31 PM
OK so there are no lights, clock, or timer built in to the range, is it a self cleaning or convection model? and how old would you say it is.
JRoot 12-04-2008 12:35 PM
I'd say 15-20 yrs old. There are 4 burners and 4 control knobs. Its not self cleaning, and is totally idependent of the oven unit. The only way I can get the humming to stop is by throwing the breaker. I have turned all of the burners on and off to se if it would affect the hum and it doesnt....
boman47k 12-04-2008 11:49 PM
That is strange. From what you describe, I would throw the breaker off and disconnect the wires at the terminals on the infinite switchs one switch at a timet hen turn the breaker back on and see if I could locate the problem, but I have some experience with the infinite switchs and the wiring. You could kill the power just to be safe and disconnect the wires at the elements. No change of getting them crossed that way as long as you put the same two back on the same element.
Btw, the infinite switches I speak of are the temp switchs that operate the individual elements.
I don't think I would let it sit there with power on while it is humming or leave it unattended. Either throw the breaker or pull the plug from the wall.
P.S. With power off, check the connections on the back of the range where the power comes in. Make sure all connections are tight there and at the elements. Wouldn't hurt to also check for tight connections on the switchs too.
JRoot 12-05-2008 06:42 AM
Thanks, I think I'll take your approach on this boman and disconnect each infinite switch one at a time. Taking a closer look at it, three of the switches have identical knobs, and the 4th is different, maybe a replacement. This will be the first one I check out.
Im still curious what could make a switch hum like that - if it is in fact the switch making the noise.
Thnks for the help so far everyone.
