Burner Insulation Under Glass Cooktop - Appliances - DIY Chatroom Home Improvement Forum
Old 05-18-2013, 04:28 PM   #1
Rewards Points: 95
Burner insulation under glass cooktop
I broke the glass cooktop on my Whirlpool range and I ordered a new one. I set the two tops side by side and unscrewed the elements and framework from the broken glasstop. I slid a piece of cardboard under the elements (which are now upside down with the glass top down) to help me lift the entire framework all at once. I got it all over to the new glass but a curved piece of cardboard-looking insulation that encases the heating elements fell out of the metal "dish" that the element rests in. The piece of "cardboard" that fell out is about 3 inches long and 1/2" deep. The heating elements are still buried in the cardboard. Is this ok or should I also buy a replacement burner? The part that disintegrated and fell out isn't even near where I broke the glass. I'm concerned the this missing insulation (or whatever that cardboard-like stuff is) will allow heat to escape to the area where all the wiring is. What is your opinion?
Thank you very much!
IDIMyself is offline   Reply With Quote
Old 05-19-2013, 06:57 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
yes, that cardboard looking stuff is high density insulation material. If it was a large chunk and you can not get it back into place I would replace the element.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-19-2013, 10:18 PM   #3
Rewards Points: 95
I think I can get it back into place.
thank you very much for responding.
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
caulking old wood windows andyman Windows and Doors 10 12-31-2011 03:39 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
Help with replacing some glass shonkster Building & Construction 5 03-12-2009 05:24 PM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
