Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-03-2012, 09:22 PM   #1
broken light bulb in door refrigerator
how can I remove a broken light bulb, only the metal base remains in the socket, there is limited space to work on the light bub in the refrigerator door that dispenses water and ice
Chris Leavitt is offline   Reply With Quote
Old 09-03-2012, 09:24 PM   #2
Unplug it, try a potato cut in 1/2.
It that does not work I use a pair of neddle nosed plyers.
Old 09-03-2012, 09:31 PM   #3
tried the potato, it just spins around.
needle nose pliers will not work due to the limited space, if they were about 2 inches in length it may work.
I did unplug the refrigerator before i tried to do any removal.
Old 09-03-2012, 09:39 PM   #4
EZ out.
Old 09-03-2012, 10:21 PM   #5
Missouri Bound's Avatar
Perhaps a short length of rubber hose....sized to fit in the base?
Do you want it your way or the right way?
Old 09-04-2012, 09:06 AM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
most likely you will have to remove the dispenser cover to give you more room to get at it
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 09-04-2012, 11:28 AM   #7
get some angled pliers maybe?
BShow is offline   Reply With Quote
Old 10-08-2012, 02:16 AM   #8
Smile
I just dealt with this same exact problem! I spent an hour two days ago trying everything from a potato to angled pliers, nothing was working because the space was just too small. Then it hit me ... I wadded up some masking tape, sticky side out, molded it into an oblong ball tapered on one end, stuck it in the socket and just kept pressing and turning counter-clockwise. Within 15 seconds I was smiling!
Coetee2 is offline   Reply With Quote
The Following User Says Thank You to Coetee2 For This Useful Post:
jschaben (10-08-2012)
need help changing out light bulb gswarriorfan Electrical 13 04-17-2012 09:43 AM
Can't get new bulb to go into Puck Light teacherfixer Electrical 2 03-25-2012 11:08 AM
How to install an outlet to a light bulb fixture. enforcefx Electrical 2 10-17-2011 09:08 AM
Light bulb sockets and wattage ratings Richo Electrical 3 10-17-2010 09:42 AM
Question about light bulb burnout arc mothra Electrical 5 04-20-2009 02:02 PM
