-   -   broken light bulb in door refrigerator (http://www.diychatroom.com/f47/broken-light-bulb-door-refrigerator-155743/)
Chris Leavitt 09-03-2012 09:22 PM
how can I remove a broken light bulb, only the metal base remains in the socket, there is limited space to work on the light bub in the refrigerator door that dispenses water and ice
joecaption 09-03-2012 09:24 PM
Unplug it, try a potato cut in 1/2.
It that does not work I use a pair of neddle nosed plyers.
Chris Leavitt 09-03-2012 09:31 PM
remove broken light bulb
tried the potato, it just spins around.
needle nose pliers will not work due to the limited space, if they were about 2 inches in length it may work.
I did unplug the refrigerator before i tried to do any removal.
joecaption 09-03-2012 09:39 PM
EZ out.
Missouri Bound 09-03-2012 10:21 PM
Perhaps a short length of rubber hose....sized to fit in the base?
hardwareman 09-04-2012 09:06 AM
most likely you will have to remove the dispenser cover to give you more room to get at it
BShow 09-04-2012 11:28 AM
get some angled pliers maybe?
http://lh5.googleusercontent.com/pub...MYG_S0UL4iCoai
Coetee2 10-08-2012 02:16 AM
I just had this happen to me!
I just dealt with this same exact problem! I spent an hour two days ago trying everything from a potato to angled pliers, nothing was working because the space was just too small. Then it hit me ... I wadded up some masking tape, sticky side out, molded it into an oblong ball tapered on one end, stuck it in the socket and just kept pressing and turning counter-clockwise. Within 15 seconds I was smiling! :thumbup:
