Broken Door Handle On GE Over The Range Microwave - Appliances - DIY Chatroom Home Improvement Forum
Old 12-16-2012, 07:16 AM   #1
raylo32's Avatar
Rewards Points: 1,282
broken door handle on GE over the range microwave
Friend has this problem... the top of the handle is completely broken off and the bottom is cracked and on its way. I don't see an obvious way to remove and replace the handle, if one is even available. Short of trying to glue it up does anyone know a good way to repair this?
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 12-16-2012, 09:01 AM   #2
raylo32's Avatar
OK, I think I figured it out. Looks like the door back just pops off... there are indents to put a flat blade in. Found the new handle online and it is $$, but what can you do?
Old 12-17-2012, 07:56 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
like you already figured out, the back does pop off. The handle is pricey but ya gotta have it.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 12-17-2012, 08:09 AM   #4
raylo32's Avatar
Yup, gotta have it and they know it. But $55 for a piece of cheap plastic is ridiculous. For some reason this particular model has one of the most expensive handles with many others being in the ~$35 range.
It's this little beauty: http://www.repairclinic.com/PartDeta.../WB15X309/2366
Old 12-17-2012, 10:24 AM   #5
Rewards Points: 340
I got hits for as low as 30.50 dollars at by searching that part number. (If the links below dont work or get removed)
http://www.partshousesupply.com/serv...crowave/Detail
http://www.ebay.com/itm/WB15X321-GE-...60921989347%26
tribe_fan is offline   Reply With Quote
Over the range Microwave geeman Appliances 6 08-04-2012 06:56 PM
Venting an oven range microwave demandrew HVAC 47 03-14-2012 06:15 AM
plugging OTR microwave into the range jpenns Electrical 13 01-30-2011 07:28 AM
OTR Microwave -> Range hood wiring A for Effort Electrical 2 07-31-2010 10:00 AM
HELP. I really need some advice on how to remove an over the range microwave! justmeee Appliances 9 12-24-2009 03:47 AM
