Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-14-2012, 09:17 PM   #1
always learning
broiler problem
I have a Kenmore gas range. model 790.78813402
Recently, when I turn on the broiler, which is on the top of the oven, the igniter glows, gas comes out, but it does not light right away, resulting in the oven filling up with gas and then finally igniting, causing a small explosion in the oven.
After searching around, I didn't find a recall and I think I may have narrowed it down to a faulty broiler element.
Should I try replacing the element and see if that fixes the problem?
theone is offline   Reply With Quote
Old 11-15-2012, 09:48 PM   #2
broiler problem
You have found the golden goose, sir.
First, make sure the thing is faulty.
Next, get an expensive house and fill it with priceless antiques.
Remove the antiques. Store them somewhere else. These should all be flammable by the way. And of course insure everything.
Now, put some steaks in the broiler, open the door a bit, and leave to get some beer at the grocery store.
Repeat as necessary until you come home to a pile of ashes.
If you really want to see something, do this when a hurricane is bearing down on you.
I guess I should mention that if this doesn't work the first few times, you should turn off the gas and let it dissipate before you enter the house.
cleveman is offline   Reply With Quote
Old 11-16-2012, 01:09 AM   #3
broiler problem
Most likely igniter. They get to about 3000 degrees and over time they degrade. Would give the symptoms you describe.
Protocol. is offline   Reply With Quote
Old 11-17-2012, 04:07 PM   #4
always learning
broiler problem
Is the igniter part of the element, or something different?
Old 11-18-2012, 03:28 AM   #5
broiler problem
Glow igniter will be a replaceable part.
It glows hot enough to ignite the gas. Sometimes they will glow red, but will not glow hot enough.
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 09:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
