Broiler Is The Only Element Working On Stove/oven - Appliances - DIY Chatroom Home Improvement Forum
Old 12-28-2012, 10:28 PM   #1
Question
Broiler is the only element working on stove/oven
My tenant said that their breaker for the stove tripped and now the only element working is the broiler. None of the stove top elements or the bottom oven element work.
Charityg is offline   Reply With Quote
Old 12-29-2012, 09:50 AM   #2
Rewards Points: 120
I would first suspect a broken, disconnected, or otherwise faulty neutral, whether at the panel, the receptacle, or the unit.
The Following User Says Thank You to DexterII For This Useful Post:
Charityg (12-29-2012)
Old 12-30-2012, 08:38 AM   #3
custom user
Rewards Points: 150
Since you're essentially talking about the potential safety of your tenant would calling a repairman be out of line? You could have a hot shorting out to ground.
JasperST is offline   Reply With Quote
Water Heater quit working!!! MikeVila Plumbing 19 12-28-2010 11:43 AM
Some things not working on a circuit while others are? speedster1 Electrical 7 11-24-2010 06:23 AM
Maytag IntelliDry pye/4500 Dryer not working 57_Hemi Electrical 2 11-19-2010 09:28 PM
Brand or OEM element in a water heater? spentonbargains Plumbing 4 10-06-2009 05:01 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 01:47 PM
