Brita Water Gives Really Bad Aftertaste - Appliances - DIY Chatroom Home Improvement Forum
Old 07-15-2010, 09:43 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Brita water gives really bad aftertaste
This was not a problem when I first got my brita, but now I find the water has very bad aftertaste. Whenever I put something like pizza in the fridge, it only gets worse. It's like if the water absorbs a "dirty fridge smell". You know that smell when you open an old fridge that has never been cleaned? The water tastes like that. The fridge does not actually smell though. I have baking soda in it but it does not seem to help the water.
Now it's actually at a point where the water gives me a sore stomac. I have not been drinking water for the past few weeks just because of this really bad aftertaste/effect. I only drink some at work from the water cooler. And yes I've changed the filter.
Other then getting a water cooler, what is a solution I could do to solve this issue? I'm thinking of making some kind of cold water tank system, that way the water will not be exposed to air. I would get one of those under the sink filter systems. Before it hits the filter, the water would be stored in some kind of tank which would be inside a bar fridge set to the lowest setting. I'd set the fridge in the crawlspace just below the sink. Think this would work?
Not sure what I'd do for the tank, thinking just a copper pipe coil or something, unless I can find an actual tank that would fit in a fridge and be able to withstand constant city water pressure. not something I want to jurry rig without it being 100% safe.
Old 07-15-2010, 10:52 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you might want to get your water tested. It might have some chemical, metal or something such as coliform bacteria.
Old 07-15-2010, 10:54 PM   #3
Wire Chewer
Rewards Points: 90
This after taste is not present when it's fresh though, it's just when it's been sitting in the fridge for about a day. If I put it in the britta and drink it right away it's ok, but just warm. If I don't use the brita then I can taste the chlorine. guess it's still worth getting it tested.
Old 07-15-2010, 11:00 PM   #4
nap
You talking to me?
nap's Avatar
I am not familiar with Brita filters so this is just a suggestion to look for something.
there are bacteria in water and I have seen filters that allowed that bacteria to grow. Is there any part of this system that simply gets used over (as oposed to changing like the filter) where the water might set in it. Maybe a good chlorine laden water soak for the thing other than the filter itself would help.
Old 07-16-2010, 06:40 PM   #5
Wire Chewer
Rewards Points: 90
Actually good point, the brita jug itself is just reused. I do wash it occasionally but it is kinda awkward to wash that thing, and it says not to put it in the dishwasher. If I was to let some javex soak in it, then rinse it with water/baking soda, would that be safe to use for drinking afterwards?
I'm also thinking I might just buy a big water jug that has a cap on it, and rather then keep water in the brita I will pour it into the water jug then close the cap off, then see if it's better.
Old 07-16-2010, 07:14 PM   #6
nap
You talking to me?
nap's Avatar
don't know what javex is so I can't really say.
I googled it.
we have a very common brand name here called Chlorox It's just "bleach". Sure, a 1/4 cup of Javex to a gallon of water should be plenty strong. Let it set for awhile and rinse very thoroughly. Probably wouldn't hurt to do the baking soda rinse. Don't know if it would help though.
Old 07-16-2010, 08:10 PM   #7
the Musigician
DangerMouse's Avatar
Smell the FRIDGE! It sounds like it's only absorbing the odors from the fridge....
Try leaving the baking soda box in there for a day or two after making sure it's cleaned out well.
There may be some stale water or spilled "something" under a crisper drawer.
DM
Old 07-16-2010, 08:38 PM   #8
Wire Chewer
Rewards Points: 90
Yeah I leave the baking soda thing in there all the time. The fridge was cleaned very well when I bought the house a year ago, because it was quite bad. Think I had use fantastic and vim, and rinsed it very well. I don't actually smell anything in the fridge, but maybe it's just very faint. Anything I could do, as far as a cleaning/freshing procedure?
Old 07-16-2010, 09:33 PM   #9
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 90
Check the pan under the fridge. It might have mold.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 07-17-2010, 05:55 AM   #10
the Musigician
If the offending odor is under the crisper drawers, or anywhere in the low part of the fridge, the smell will follow the cool air when you open the door. You'll likely not smell it much if at all, but when the door is closed and the air is circulating.... which brings me to the next possibility, the freezer.... Was it scrubbed clean too?
DM
Old 08-03-2010, 02:10 PM   #11
Wire Chewer
Rewards Points: 90
Yep freezer was scrubbed too. Now the under of the fridge is very dusty and disgusting. Could that have any effect? I cleaned it the best I could with the shop vac but was hard getting in there.
I can confirm the water is what gives me these sore stomachs though, I just got another immediately after drinking a glass. I'm in a bad dilima now, I have twitching eye, probably due to all the pop I've been drinking instead of water, but if I drink water I get a sore stomac lol.
Might be time to just buy the fresh water jugs. At least they have a cap so they can be sealed. I can just refill it with the brita I suppose.
Old 08-06-2010, 11:20 AM   #12
bbo
I would really clean everything out. you are not doing yourself ang good by masking the problem by covering the water with a cap. what about all the other items in the fridge?
and I would avoid using bleach. it's not the best thing to breath in either. Vinegar should do fine as a cleaning agent. And you can always up the concentration of vinegar with many less ill effects then bleach. The important thing is to thoroughly clean the fridge and brita and then use a new filter for the brita.
toss anything in the fridge thats even remotely iffy. food is cheaper to buy than good health.
If you use bleach, start with a very low concentration. no need to go all out. the fumes from a high concentration can give you headaches.
and NEVER NEVER NEVER mix bleach and vinegar.
bbo is offline   Reply With Quote
Old 08-06-2010, 11:27 AM   #13
the Musigician
...or bleach and ammonia....
Po)
DM
Old 08-06-2010, 12:52 PM   #14
Wire Chewer
Rewards Points: 90
That's the odd thing, the other items taste fine, but maybe because their own taste masks the taste I get with water?
It was thoroughly cleaned but I think I will try it again. I may need to take the air vents apart if it's even easily done, as the smell is probably in there and just circulates.
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 01:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
No Hot Water comeing out of Faucets gangstacro Plumbing 5 11-30-2008 03:32 PM
