#1 |
Bottom (bake) element in the oven dead?
So, cooking a pizza last night and about 5-10 minutes in the wife heard a strange noise and opened the oven and the bake element at the rear right corner of the stove was sparking and a brighter red than the rest of the element.
Naturally, we turned the oven off and tried it again a few minutes later and the element did not come back on at all. We tried the broil element and that seemed ok. After inspecting the oven I noticed the bake element rear right corner that was sparking was off level and touching the interior of the oven. The front right bracket became unnattached which was causing it to tilt in the back. Would this be the cause of the sparking and dead element? (metal touching metal) I will try and post pictures later tonight. I would much rather try and replace the element rather than buy a new stove. Some other info. We just moved into our house about 6 months ago and the appliances came with it. The stove looks fairly old 10-15 years perhaps. When cooking, we found the oven cooked food pretty quickly. Example, if the pizza box states that you should cook at 400 for 10 minutes, we would cook at 300 for 10 minutes and it would be very crispy. Any thoughts? |
#2 |
It was a dark and stormy
Could be burned out element, bad connection to the element or burned out switch contacts that fed the element.
If you can find the rated power of the element from a parts place, the element resistance in ohms should be 57600/P, where P is in watts. So if P is 3000w, R would be ~19 ohms. |
#3 |
Here are some pictures:
#4 |
Replaced the element yesterday and it seemed to do the trick. Rewarded myself by baking a tasty apple crisp and it turned out well.
On the downside, when I was bending down to unplug the stove, I cracked my head off of the range getting back up. Ouch |
| Display Modes | |
| SCARY oven fire! Why did it burn? | Beth777 | Appliances | 63 | 01-20-2013 07:55 PM |
| Sequence of operation hot water heater | pomelo | Plumbing | 5 | 01-25-2010 12:29 PM |
| Gas oven problems | gregsmy | Appliances | 1 | 12-03-2009 06:55 AM |
| Replaced lower element in Magic Chef oven still doesn't work | sneakyd | Appliances | 2 | 12-10-2008 09:51 AM |
| Oven Blew Up at Connector with Element | cynthiap | Appliances | 5 | 11-26-2008 07:30 PM |
