Bosch Washer With 220 Plug - Appliances - DIY Chatroom Home Improvement Forum
Old 07-19-2013, 01:17 PM   #1
Smile
Bosch washer with 220 plug
Hi, Just moved into new apartment with bosch stackable units, how do I setup with only normal outlet available?
JaneenF is offline   Reply With Quote
Old 07-19-2013, 04:02 PM   #2
Rewards Points: 734
By normal I assume you mean 120 volt outlets.
You don't since it's an apartment. Call an electrician. You'll need to rewire the outlet or replace the stackable.
If it's a dedicated outlet you may get lucky.
AandPDan is offline   Reply With Quote
Old 07-19-2013, 04:20 PM   #3
Rewards Points: 1,294
knowing your location would help a lot too. Most assume everyone is from north America. This could be a European appliance.
danpik is offline   Reply With Quote
Tags
110/220 , 220v , bosch , convert 220
My new Bosch washer requires 208/240 volts libby1222 Electrical 20 01-09-2016 06:33 AM
Frigidaire Affinity front loading washer 2006 model-won't spin final spin? imola ghost Appliances 9 10-23-2015 05:23 AM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 12:00 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Washer tray drain plug proofer Appliances 5 08-24-2008 09:53 PM
