Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 08-06-2011, 12:54 AM   #1
Bosch Error 43
I have a Bosch HGS255UC/01 and replaced the control board since I was advised to, due to an Error 45. Now I am getting an Error 43. Any real help would be appreciated
logon2k is offline   Reply With Quote
Old 08-06-2011, 01:46 AM   #2
Bosch Error 43
Have you tried turning off the oven circuit for at least five minutes to allow a reset? I looked for a manual, but I couldn't find anything for that model. Do you have a service manual that explains all your diagnostic codes? I know that for a different model Bosch range, code 43 has something to do with the door lock mechanism. If you can't find a service manual, you might find something inside the cabinet.
benjamincall is offline   Reply With Quote
Old 08-06-2011, 01:50 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Bosch Error 43
F43 means the upper oven latch will not unlock. It may be a bad switch, latch or latch motor. Replace the upper door lock latch assy
F45 means the upper oven latch is stuck in both lock and unlock.
I suspect that the door latch has been the problem all along and you didn't need to replace the board. So much for saving the price of a service call.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 08-06-2011, 02:50 PM   #4
Bosch Error 43
Fortunately, you can recover some of the cost of your board on an online auction site.
Bosch vs. Porter Cable 18v drills bclarknc Tools 8 04-27-2012 04:59 PM
Laser died - need suggestions for a replacement - thinking about Bosch... restorick Tools 0 04-07-2010 10:04 AM
Bosch Dishwasher - No Insulation?? NateHanson Appliances 2 12-16-2009 06:46 AM
Portable Bosch 4100-09 with gravity rise stand jmw-1955 Tools 0 12-05-2009 01:31 PM
Makita versus bosch stuart23 Tools 5 11-15-2007 09:41 AM
