-   -   Bosch Error 43 (http://www.diychatroom.com/f47/bosch-error-43-a-113105/)
logon2k 08-06-2011 12:54 AM
Bosch Error 43
I have a Bosch HGS255UC/01 and replaced the control board since I was advised to, due to an Error 45. Now I am getting an Error 43. Any real help would be appreciated
benjamincall 08-06-2011 01:46 AM
Have you tried turning off the oven circuit for at least five minutes to allow a reset? I looked for a manual, but I couldn't find anything for that model. Do you have a service manual that explains all your diagnostic codes? I know that for a different model Bosch range, code 43 has something to do with the door lock mechanism. If you can't find a service manual, you might find something inside the cabinet.
hardwareman 08-06-2011 01:50 PM
F43 means the upper oven latch will not unlock. It may be a bad switch, latch or latch motor. Replace the upper door lock latch assy
F45 means the upper oven latch is stuck in both lock and unlock.
I suspect that the door latch has been the problem all along and you didn't need to replace the board. So much for saving the price of a service call.
benjamincall 08-06-2011 02:50 PM
Fortunately, you can recover some of the cost of your board on an online auction site.
