Blower Fan Continually Runs After Heat Has Stoped - Appliances - DIY Chatroom Home Improvement Forum
Old 11-11-2011, 01:05 PM   #1
Blower fan continually runs after heat has stoped
How do I troubleshoot this issue?
Bob Stein is offline   Reply With Quote
Old 11-11-2011, 01:07 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Are you saying it never shuts off? Never ever!
XXX
Old 11-11-2011, 01:49 PM   #3
Correct. The heat shuts off but the fan keeps running and never shuts off.
Old 11-11-2011, 02:23 PM   #4
raylo32's Avatar
Rewards Points: 1,294
Are you sure you don't have the fan selector on your t-stat in the "on" position?
raylo32 is offline   Reply With Quote
Old 11-11-2011, 02:35 PM   #5
It's in the auto position but the fan runs as if it is in the on position.
Old 11-11-2011, 02:42 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay someone that knows about these things will be along after work and should be able to help. My guess is bad limit switch but I don't know what I'm talking about. Maybe that isn't what it is called.
Until someone else does dive in - how long has it been doing this?
XXX
Old 11-11-2011, 03:06 PM   #7
raylo32's Avatar
First thing I would check is to see if you have 24vac to the g terminal of the furnace board when the heat is off the and blower is still running. If there is voltage there then you probably have a bad t-stat or a short in the stat wiring.
Otherwise it could be the furnace circuit board. Generally the blower should run for a minute or 2 after the heat call is satisifed and the burner goes out to extract the heat and cool the heat exchanger. I believe that this can determined by temp or more likely just a fixed time. It would depend on the model of your furnace and how it controls this to figure out if it is the main circuit board or something else.
Post your exact brand/model.
Furnace blower not working on heat mode Sixshot HVAC 1 10-26-2011 08:02 AM
blower runs, with no heat captjack HVAC 6 12-14-2010 02:15 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Blower motor in old bryant furnace runs constantly GetYourShineBox HVAC 2 07-20-2010 07:49 PM
Heat Pump wont run, but Blower fan runs Roger M HVAC 1 07-09-2010 04:18 PM
