Bissell Proheat Carpet Cleaner - Appliances - DIY Chatroom Home Improvement Forum
Old 09-08-2010, 08:34 AM   #1
Hello
My name is Carol and I am having a problem with my bissell proheat carpet cleaner. When I press the nozzle it won't spray solution on the carpet. I've gone through the manual but can't figure out what might be causing the problem. Any suggestions appreciated.
Thank you
vtcarol50 is offline   Reply With Quote
Old 09-08-2010, 09:19 AM   #2
fabrk8r
fabrk8r's Avatar
If the carpet cleaner hasn't been used for a while it may be as simple as clogged nozzles. It could also be a bad connection at either the trigger or the sprayer.
I'd check the nozzles first and go from there.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-08-2010, 09:23 AM   #3
Bissell Pro Heat Carpet Cleaner
Hello,
Thank you, I will do that.
Old 09-08-2010, 02:37 PM   #4
Tizzer's Avatar
Rewards Points: 452
I'll add this only because I've seen it happen at least 3 times. The user had put the solution in the wrong tank.
Tizzer is offline   Reply With Quote
Old 09-14-2010, 11:56 AM   #5
Bissell
If you are continuing to have an issue with the unit not spraying email BISSELL consumer services at bissellcsr@bissell.com for further assistance.
BISSELLCSR is offline   Reply With Quote
Old 09-17-2010, 07:21 AM   #6
Some of these models have a belt driven pump in the front brush area. If you have pets sometimes pet hair can clog the belts and stop or break the belt to the pump.
Idmason60 is offline   Reply With Quote
Old 11-13-2010, 12:05 AM   #7
Would anyone have a repair manual for the Proheat Clearview Model No. 1699. I bought a new trigger and spring for the upper handle and I can't get it back together properly. Or possibly a picture of how the upper handle goes back together. I don't know where the long bar inside and the spring should go. Any help greatly appreciated.
In addition, there is also water in one of the hoses by the heater. How would I clear this out.
Thank you in advance for any suggestions.
bissell carpet cleaner melloneyjane Electrical 1 06-29-2010 10:34 AM
bubble under carpet after water spill - fixing psittacus Flooring 4 03-06-2009 02:23 AM
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr chetsy Off Topic 9 12-03-2008 07:41 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
