Originally Posted by Chemist1961
Next time buy your carpet cleaner or rent one at the vacuum center, not at Wal Mart... or similar. Ask them which brand they recommend.
I asked the proprietor of the repair shop which brand he recommends from a "frequency of repairs" standpoint...he said he never sees a Hoover in his shop.
I know they are expensive, though!
I had a Kenmore and never had any sort of problem with it.....loaned it out to a friend, never saw it again after they moved. So much for that one
Your repair shop is being straight up. I discontinued servicing Bissell products for that reason, continuous clogging and brittle plastic that fatigued and broke very easily, over and over in the same spots.
Are the jets consumer replaceable? I'm pretty handy with mechanical repairs and if we can order replacements I'm sure I can manage the swap.
I think Becky rinses the soapy water out of the unit after she uses it, but the repair shop owner also mentioned running a rinse through the jets to get rid of the soap scum. Once we get it back, we'll be sure to do that. In the past I have rinsed the carpet with clear water after shampooing it, the house ended up smelling like a cat-box for a week b/c a wet weather front rolled through. I guess the carpet was so wet it "soured".
We've already decided this is the last time we'll pay $50 for cleaning the jets...when it goes down again, it gets trashed and we have what Becky calls a "shopportunity".
The water here in Huntsville, TX is of "superior" quality, according to the sign at the city limits, but it is quite full of minerals (and occasionally smells like sulphur) and that has been a source of problems in other plumbing areas in the past.
She thought she bought a good brand when she bought a Bissell...guess hindsight is 20/20, eh?
I've had the case apart on this unit in the past...finding the "jets" can't be hard, they have to be on the ends of the hoses coming out of the pump.
Originally Posted by joecaption
Have you ever contacted Bissle about your problum?
Not yet, but that is on the agenda for today...found their "contact us" section on their website. We'll see what they have to say.
Thanks for the replies so far, folks! I've wondered about running a dilute solution of CLR through the unit after the final rinse each time we use it.
...onward through the fog
Cheers!
Dugly
