Best Solution For Air Purification - Appliances - DIY Chatroom Home Improvement Forum
Old 12-05-2009, 12:59 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
Best solution for air purification
I've been getting lot of colds latetly, pretty much since I moved into my house. I'm starting to think it's an air quality issue. The ducts are in bad need of being cleaned, and I'm not sure when is the last time the filter got changed, and on top of it all the construction work caused dust that might still be lingering around.
What is my best solution to remedy this? Getting the ducts cleaned is a given, I want to get that done soon. Would installing a hepa filter help out a lot as well? Can these be purchased at the hardware store along with regular filters or is this something more specialized and expensive?
Would a portable air purifier do the trick for now?
Old 12-06-2009, 02:07 PM   #2
Rewards Points: 410
New Home ? is it brand new? lots of off gassing and dust and now its shut up tight for winter.
At the very least change your furnace filter frequently.
I speced out an April Air furnace filter ( its several inches thick) for my new home.
I had one in my old place and they do pretty well.
http://www.aprilaire.com/index.php?c...on=ProductsCat
Before that I had an electrostatic filter on my forced air furnace for several years.
They work by far the best in my experience but you have to pull the ' radiaters' to soak/clean then every few weeks.
http://yourhome.honeywell.com/Consum...ic/Default.htm
Here's another type filter thats portable and will do practicality a whole house.
http://www.healthpurifiers.com/index...in-air-cleaner
I have the healthmate, this is a hepa type and will collect offgassing.
You could get the junior model and put it in your bedroom at night.
If its allergies , could be dust mites , high thread count sheets and pillow cases will help.
Carpeting ? A central vac system is the best way ( I have it) or get a hepa filter for your portable cleaner.
It could be environmental . I lived for years close to a 4 lane highway(exhaust pollutants) with a park with wetlands(mold) 50 yrds on the other side.
The school where our son went had mold issues.
Our son developed athsma real bad , I had allergies.
We built out in the country a couple of years ago now and am healthier for it.
The new house has mostly wood floors , central vac, april air filter.
I only need to run the austin cleaner when I'm wood working in the basement.
High Gear is offline   Reply With Quote
Old 12-06-2009, 08:16 PM   #3
Wire Chewer
Rewards Points: 126
My house is mostly hardwood floors which is good and I have a central vac, I think once I take care of all the dust it will hopefully help, and I also need to get the ducts cleaned. I will look at the portable filters for now as I'm on a tight budget. How much do the ones built into the furnace go for, and is that something I can install myself or would I need to get a HVAC guy to resize everything?
Old 12-06-2009, 09:31 PM   #4
Rewards Points: 410
Here's an outfit that geared for the do it yourself.
It has videos on the products and how to install and the sheet metal transition kits needed.
http://www.alpinehomeair.com/viewcat...?categoryID=77
Old 12-07-2009, 04:38 AM   #5
An old Tradesmen
Rewards Points: 7,270
How old is the furnace.
Are you sure your not getting CO or CO2 pulled into your duct system?
Old 10-25-2010, 10:05 AM   #6
HEPA technology is able to remove at least 99.93% of airborne particles. It will certainly help with your problem.
The drawbacks of HEPA air purifying systems are considerable noise that can be annoying for some people. They usually use replaceable filters that can last up to a few years, depending on the level of air pollution in your house, but sometimes HEPA filters can not be replaced, and you should be careful to find out this detail before purchasing your air purifying system. HEPA filters are the best for capturing allergies, bacteria and mechanical particles from the air. And once captured, they are never released in the air. But they are ineffective against gas pollutions, fumes, odors and cigarette smoke.
Source: http://air-cleaner-systems.com/HEPA-air-purifiers.html
LilN is offline   Reply With Quote
Old 10-25-2010, 05:15 PM   #7
Hepa is an acronym for High Efficiency Particulate Air filter. They may help, can't hurt great if its allergies. On a tight budget, you could also look into a Swordfish for the furnace, often on sale at CDN Tire for 30% off....
Definitely do the ducts and if you need a 24x 20 size filter box for the furnace I have a spare, brand new in Waterloo, available cheap... PM me.
Also suggest you read up on Oil of Oregano. Nothing has reduced my colds and allergies like it has... I feel bullet proof but used to get a lot of bad chest colds since having pneumonia as a child, (real pneumonia, 7 days in an oxygen tent, not my kid has "pneumonia" because he sneezed like every paranoid parent thinks today.)
Chemist1961 is offline   Reply With Quote
Old 10-25-2010, 07:42 PM   #8
What about the Trane Perfect Fit Electronic Air Clearner / Clean Effects http://trane.com/Residential/Product...Air-Filtration
Anyone really know which is the best Filter/Cleaner at a reasonable price?
tysfamily is offline   Reply With Quote
Old 10-26-2010, 08:08 AM   #9
I think so. Try to use an air purifier that suits for you and your family.
aeon20 is offline   Reply With Quote
Old 12-11-2010, 08:55 AM   #10
Wow - Bad Air Purification advice
I'm a technician and this wasn't very good advice. For air problems causing colds and flu is not likely going to be solved with a HEPA purifier. This video Air Purifiers: Can they kill viruses and germs? shows how you have to have UV light and Tio2 to do a good job at killing germs, viruses, and bacteria (let alone mold..
Bob Evans - HVAC Expert
http://www.top-air-purifier-reviews.org/
BobEvans is offline   Reply With Quote
Old 01-06-2011, 05:23 PM   #11
Try Virus Zero Air Sterilizer
Don't post just to adevertise your product, please pay to advertise, Thank you.
viruszero is offline   Reply With Quote
Old 01-06-2011, 05:26 PM   #12
New home causes VOCs
VOC stands for Volatile Organic Compounds which generated from new paint, new funiture materials, etc.
Last edited by beenthere; 01-06-2011 at 05:45 PM. Reason: removed advertising text
Old 01-06-2011, 05:45 PM   #13
An old Tradesmen
virus.
If you want to advertise here, pay for it.
Old 01-06-2011, 05:49 PM   #14
Well noted.
Originally Posted by beenthere View Post
virus.
Need HVAC solution for basement - 3 zone? or ductless units? skylake HVAC 2 10-06-2009 07:42 PM
Need lighting control solution mmccarty Electrical 9 08-25-2009 09:13 PM
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 07:31 AM
Best solution for low-par floorboards joshier Carpentry 1 08-13-2008 04:36 PM
unconventional solution nique Plumbing 5 12-10-2006 10:34 AM
