Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 07-16-2007, 10:39 PM   #1
Default Best Garage Door Opener?
Hello,
I am about to close on a house. The house has a two-car garage, and I'd like to install a Garage Door Opener. I looked online and I see all types: chain-driven, belt-driven, 1/2hp, 3/4hp and so on.
Here's a picture of the garage:
Which type of "GDO" do you recommend (durability, price, warranty...)?
Thank you in advance!
-Walter
Treppiede is offline   Reply With Quote
Old 07-17-2007, 01:27 AM   #2
Default Best GDO
First you will have to move that ducting beyond the left center of door You can buy metal ducts and transition from round to square so GDO mechanism will go over. Square metal ducting will be flush against the ceiling. I bought a Genie brand from a big box store that has a uniquie chain design from some older ones I've seen. Was easy to install as I've done others for other people. Some of the house brands Do it best etc may have more plastic gearing which can strip etc if safety mechanisms are adjusted proper. !/2 HP for that door ,looks to be wood and springs were adjusted so you didn't get a hernia! Good luck!
-Walter[/quote]
roger1 is offline   Reply With Quote
Old 07-17-2007, 06:37 PM   #3
Stay as far a way from genie as you can. Go with a liftmaster belt drive if you like it quiet or chain drive a bit more noisy. 1/2 HP will be sufficient or you can go up to 3/4 HP and it wont hurt. Have them fix that door before closing. There should not be a gap under the door on the right side. The duct work looks like it is behind the door so it shouldn't be in the way.
Doorguy06 is offline   Reply With Quote
Old 07-17-2007, 07:57 PM   #4
Eibwen
I have a Genie excelerator in use for three years now with several open/closes daily and no complaints with a little maint. The interior button/console did die but it has a lifetime warranty so it only cost me five bucks shipping for a new button and they ended up sending a whole new control circuit board in the shipment.
Its a screw drive and is quieter than a chain drive, but belt drive is the quietest if noise is an issue.
No experience with them but Wayne Dalton makes an I drive which mounts across the top of the door versus coming out into the garage. Pricey, but looks neater and would eliminate the duct issue.
Sammy is offline   Reply With Quote
Old 07-18-2007, 12:34 PM   #5
I tried "Wayne Dalton" before... it is a nightmare... it might work for single door... but for double door... it just don't have the power... I bought it new around $200 bucks and sold the used one for $30 after trying to use it in one year.... to be fair, if the garage door is perfectly balance, it might work... but how many garage door is perfectly balance ?
KUIPORNG is offline   Reply With Quote
Old 07-22-2007, 12:43 AM   #6
If you have money spend money on a good GDO. I had an old craftsman chain lift for a while it just got to noise. Now I have the Genie 1/2hp screw much quiter and nice remotes controls. My door had a broken spring I replace myself and balance the door perfectly. A good balance door shouldn't have any resistance when going up or down the springs do all the work.
jorguez1167 is offline   Reply With Quote
Old 07-23-2007, 08:48 AM   #7
RippySkippy's Avatar
Originally Posted by KUI****G View Post
...but how many garage door is perfectly balance ?
If the door isn't in balance...a larger opener is the least of one's concerns, a door out of balance will either eat door openers, or wreck the door.
As jorguez1167 said...the door should be balanced enough to hold itself, the opener just does the lazy work. The adjustment part is a whole 'nother story tho...if the owner isn't comfortable with adjusting the tension, hire it out.
I like the genie openers...still not quite sure the accelerator is necessary. I'd be more concerned with the daylight showing under the right side...that says the cables and spools are not in alignment with each other. If you don't know how to do this and do it safely, hire it out.
RippySkippy is offline   Reply With Quote
Old 07-24-2007, 10:50 PM   #8
General Contractor
joasis's Avatar
Let me add this warning: Under no circumstances should torsion springs be adjusted by a DIY'er. These can be dangerous, and should be left to pro's....it isn't worth loosing your front teeth, or an eye....maybe breaking an arm, or having one explode (yes, they can and do literally explode) and send shrapnel into your body. Same thing with the lift cables and drums...leave this to a pro.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulation Services
Oklahoma
405 314 5802
joasis is offline   Reply With Quote
Old 07-24-2007, 11:13 PM   #9
Eibwen
Roger that Joasis.
I have seen springs fly around a garage when they break.
HIRE A PRO to do that!
Old 07-26-2007, 01:09 PM   #10
My Father-in-law Worked In The Garage Door Industry For 30 Years. He Recomended The Liftmaster (chain Drive)to Me 15 Years Ago And It Still Works Like New. I Will Say I Agree With The Posts That Suggest The Door Be Adjusted And Springs Adjusted By A Professional. Also Make Sure The Rollers On The Springs Are Well Lubricated...this Is What Makes A Door Go Up And Down Quietly....not The Operator (opener)
BDURR67 is offline   Reply With Quote
More On This Topic
Learn how to grind metal parts smooth when doing body work and restoring a car in this free DIY car-restoration video from our expert mechanic and body shop owner. Read More »
We're going to try first, to pull their existing duct work. I've checked with all the mechanicals, it looks like this air conditioning system can carry the load, of this extra square footage. We're going to try that first, if we need to then supplement... Read More »
Part 2 - Learn how to adjust the guitar string action to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
The first Hudson rolled off the assembly line in 1909. The car was named after its benefactor J. L. Hudson. What is unique about Hudson cars is the company's shift from buying engine parts to manufacturing them in-house--Hudson cars were built with their... Read More »
On behalf of expertvillage.com my name is Neal Jones and I’m with A Perfect Fit Alterations, 102 Main Street, Burleson, Texas, our phone number is 817-447-3522. Continuing with our threading of our basic machine, we were able to get the thread... Read More »
New Heated Garage: need help! HardcoreCBR General Discussion 12 05-23-2008 09:34 AM
Converting Carport to Garage viking1974 Building & Construction 2 08-13-2007 12:38 AM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 04:09 PM
Garage Concrete Slab...HELP? Aqua-Man Building & Construction 2 06-17-2005 03:11 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
