Bad Smell In Dryer - Appliances - DIY Chatroom Home Improvement Forum
Old 07-13-2009, 09:02 AM   #1
Bad Smell in Dryer
We went on vacation for about five days and when we returned, we noticed an awful smell around our clothes dryer. We thought a wet wash cloth or towel could be the culprit but we've washed everything, cleaned the dryer thoroughly, and pulled out the dryer and the washer to make sure there was no dead rodent in the area but we found nothing and no amount of cleaning or air freshener seems to get rid of the odor. It's worse just after the dryer has been running or after opening the dryer door after it has been closed up for a while. It does smell like a dead animal but we've looked everywhere - even in the hose and can't find anything. Has anyone else encountered a problem like this? The smell initially seemed to be contained to the dryer but it seems to be now spreading througout the entire laundry area.
lking7 is offline   Reply With Quote
Old 07-13-2009, 12:17 PM   #2
diy mike's Avatar
If you haven't yet, I'd check the vent duct. I've had chipmunks get trapped in there before... but (fortunately) I found them while they were still alive.
diy mike is offline   Reply With Quote
Old 07-13-2009, 03:54 PM   #3
General Contractor
Check and make sure nothing got into where the element is. If a mouse or other animal got in the dryer and was touching the element when the dryer was turned on, it would get electrocuted. Every time the dryer is turned on afterward would further char the remains. It makes a pretty foul smell from what I've been told.
ARI001 is offline   Reply With Quote
Old 07-17-2009, 10:19 AM   #4
General Contractor
Old 07-19-2009, 09:09 AM   #5
Nasty work if there is something dead in there, but detach the vent. Unplug the dryer and look in the exhaust tube under the dryer. This is the lowest point where the squirrel cage sits. Unlikely ANYTHING COULD GET PAST THERE into the dryer itself.
Check the vent line all the way outside. If you have damper or screen on it, it is also unlikely anything could get in but if there is no cover a critter could crawl in and fall down inside. If you are unsure try to roll a tennis ball through from outside, if your vent pipe is not buried behind a wall.
A mouse could get into the element area with a lot of effort but the element is generally pretty well protected to avoid contact with clothes.
Do you have rotting smell or an acrid burned hair and cooked smell....
when this is done, install a new vent with a weighted damper. This will ensure the door closes fully outside and keep cold air out at the same time
Chemist1961 is offline   Reply With Quote
Old 02-11-2013, 10:19 PM   #6
Iking7 did you ever get the smell out of your dyrer? Mine does the same thing. ( wet dog smell )
bmannvmax is offline   Reply With Quote
Old 02-12-2013, 09:04 AM   #7
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
you will have to disassemble the entire dryer until you find the culprit. I've seen everything from mice to squirrels
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 12:01 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 09:37 PM
Dryer Pony Problem. Hobb3s Electrical 17 09-30-2008 09:16 PM
