Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 02-16-2009, 11:51 AM   #1
Audio amp odd wiring...
I was changing out a cord on my amp with a new one and looked at the wiring. The neutral was fused and switched, not the hot. Why would this be?
I did not change anything, kept the neutral fused and switched.
Load is just a regular toroidal x-former.
rgsgww is offline   Reply With Quote
Old 02-17-2009, 06:57 AM   #2
Did you do a continuity check on the old power cord from the wire end to the blade on the male end?
I've seen some where the colors are not what you would expect, I think they use some international,
not US color standard.
Revue is offline   Reply With Quote
Old 02-17-2009, 08:24 AM   #3
No, the plug was polarized. It probably doesn't matter much, but I might fuse the hot and switch it. Thats how its always done.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 33 03-18-2009 08:11 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 11:33 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
