Attic Exhaust Fan Running Constantly. - Appliances - DIY Chatroom Home Improvement Forum
Old 04-17-2014, 10:08 AM   #1
Attic Exhaust Fan running constantly.
I've noticed in recent weeks and months that my attic fan has been running constantly, non stop, literally. Even on very cool days and nights. My question is how do I stop this. Is there a switch that I should find. Would it be located in the attic area or the bedroom. Should I call a professional to disconnect it? Or is there anything I can do to turn it off?
It makes noise also
R.Ny is offline   Reply With Quote
Old 04-17-2014, 10:35 AM   #2
Rewards Points: 12,808
Most have a thermostat mounted on the fan some place so it only runs when it hits a set temp.
No one here's going to know if your fan has a switch or not, someone's going to have to go up in the attic and look. Just depends on how it was wired, some do, some do not.
If someone hot wired it the only way to shut it off to work on it would be to shut off the breaker supplying power to it.
I never install powered fans anymore. I use ridge vents.
No power needed, no noise, vents the whole roof not just a circle.
R.Ny (04-20-2014)
Old 04-17-2014, 10:38 AM   #3
Civil Engineer
Rewards Points: 4,514
My attic fan is equipped with a thermal switch. You set the temperature, it turns on. I have mine set so when the attic gets over 90 degrees F, the fan turns on, but you can set it to any temperature. You may have such a switch, you need to look at the incoming power cable to see if it goes through a temperature switch. Sometimes the fan comes wired with a timer, you can set it to run during the day and turn off at night. Sometimes the fan has a manual turnoff switch. Sometimes there is no external switch at all, instead there may be an internal temperature switch that you may be able to set, you need to look at the manual. Sometimes the fans are plug ins to a wall outlet, in which case you can always take out the plug.
A picture of the fan might help identify what you have.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
R.Ny (04-20-2014)
Old 04-18-2014, 11:34 AM   #4
I have set my thermal switch to 90 F also. Is it the right temp. to set in NJ
might be that will help.
thanks all
Old 04-18-2014, 05:01 PM   #5
Should be fine.
R.Ny (04-20-2014)
Running wires through an unfinished attic EdwardButters Electrical 13 02-06-2013 10:16 AM
Attic - Replacing electrical - Positioning, how many boxes, checking understandings darlingm Electrical 12 12-05-2011 12:17 AM
Fan constantly running with Goodman CPLE30-1 Kast HVAC 0 07-25-2011 11:02 AM
Bathroom Exhaust Fan Venting into Attic koz123 HVAC 10 01-21-2011 09:05 PM
running ethernet through attic null_pointer_us Building & Construction 3 05-15-2006 06:08 PM
