Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-25-2011, 09:45 PM   #1
asko 3530 install problem
I am installing an ASKO 3530 dishwasher but I have run into a frustrating problem. The water-in line appears to be a 3/8 pec-type hose - but in fact, it's diameter is slightly larger (maybe 1 mm) - and so I cannot put on a pressure fitting 3/8inOD as would seem appropriate. What can I do ? I cut a piece of the hose and brought it to 3 local plumbing shops but did not get a solution. They thought it might be a metric vs. imperial problem, (I am in Canada) but I called Asko and they assured me that this model (its from a few years ago) should have a 3/8 water-in hose coming out the back - but IT DOED NOT - it has a slightly larger diameter hose !! I suppose I can try to replace the hose completely but it seems to be imbedded quite deep in the bowels of the machine. There must be an easier solution. Any help here would be most appreciated. Thanks.
patrick111 is offline   Reply With Quote
Old 11-26-2011, 09:05 PM   #2
sand it down i know really time consuming
wait, plastic or copper
if copper it could be brazed onto the female end of a fitting or soldered
kennzz05 is offline   Reply With Quote
Tags
3/8, asko, install, problem
Luxaire Acclimate 9M Natural Gas Problem Trailwalker HVAC 9 12-18-2010 05:25 PM
I want to install laminate plank flooring but have problem with sub floor In the Bush Flooring 3 04-29-2009 01:35 PM
Window install question reguarding tyvek marlinpuppy Building & Construction 2 02-12-2009 12:56 PM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 02:02 PM
Prehung Door install problem bscj@innernet.net General Discussion 3 04-08-2008 11:40 PM
