Appliances - Appliances - DIY Chatroom Home Improvement Forum
Old 01-11-2012, 07:26 PM   #1
Appliances
what should the height be from the bottom of an over the range microwave oven to the top of the electric stove.
Don Jo is offline   Reply With Quote
Old 01-11-2012, 08:08 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
min. 32"
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-12-2012, 11:32 AM   #3
"min 32" ? oops!
Jacques is offline   Reply With Quote
Old 01-12-2012, 11:38 AM   #4
Ironlight's Avatar
The standard guideline for range hoods is 24"-30", but the ideal height really varies based on the capacity of your stove, the type of hood that you have, the type of cooking that you do, and of course the height of the adjoining wall cabinets that are above it and next to it.
With above-range microwaves the height is usually on the low side because a) the blowers are not that strong b) you don't want the microwave so high it is difficult to use and c) the cabinets above are a standard height and you want everything to line up properly from a fit-and-finish perspective.
Ironlight is offline   Reply With Quote
Old 01-13-2012, 08:10 AM   #5
Just pick one out and look up the spec's for install. most/all? call for min-66" from floor to bottom of cabinet. min-30" from cooktop to bottom of cabinet. [ most m/o are 16" high]. should be no prob in standard kitchen.
Storing Appliances in Unconditioned Space Pittsville Appliances 2 01-05-2012 10:02 PM
Using the correct fuses in appliances? razorcut Electrical 2 06-11-2011 10:38 AM
European Appliances... A Question of Amps and Watts??? Dazzlin Electrical 3 08-09-2010 10:06 AM
New stainless appliances poolecw Appliances 2 12-04-2008 03:23 PM
Are European appliances really that much better? home_improver Appliances 2 09-30-2008 07:06 PM
