Appliance Repair - Appliances - DIY Chatroom Home Improvement Forum
Old 05-04-2011, 12:24 PM   #1
appliance repair
I have a side by side whirlpool refrigerator, model number ED2FHGXKQ00. The icemaker has stopped working but the water dispenser works fine. The icemaker is in the door. Any ideas?
pebbles is offline   Reply With Quote
Old 05-04-2011, 08:40 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
call an appliance tech. It could be a number of things, the optics may have gone out, the valve may be bad, the fill tube may be frozen or most likely the entire icemaker needs replaced (very common with these).
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 04-27-2016, 10:37 AM   #3
Rewards Points: 4
Re: appliance repair
when you press for ice does the motor run to dispense the ice ?
shawnc704 is offline   Reply With Quote
Old 04-27-2016, 10:43 AM   #4
Rewards Points: 4
if the motor runs to dispense the ice when the button is pressed then inspect the ice maker first make sure that it is in the on position then make sure a piece of ice isn't restricting the fingers that push out the ice
The Following User Says Thank You to shawnc704 For This Useful Post:
Canarywood1 (04-27-2016)
Old 04-28-2016, 11:38 AM   #5
Rewards Points: 320
I'm sure he/she got it fixed by now, thread is over 5 years old. However, if other people are researching you provided good advice for anyone else with similar issue.
jmon is offline   Reply With Quote
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 10:45 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Repair Compounds saggdevil Painting 3 04-25-2010 03:02 PM
magazine or any appliance repair material ccc Appliances 0 10-26-2009 10:27 AM
Issues with appliance plug hgiljr Electrical 1 03-17-2007 07:09 AM
