Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 08-24-2011, 12:23 PM   #1
AO Smith gas water heater - main burner won't stay lit
water heater has electronic ignition. Pilot lights successfully, main burner comes on but after a few minutes the system shuts down.
ianshomeimp is offline   Reply With Quote
Old 04-08-2012, 07:31 PM   #2
Any fix on this?
Fortypopper is offline   Reply With Quote
Old 05-31-2012, 09:22 PM   #3
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
what type of w/h power vent,direct vent,flame guard? does the flame and pilot go out and is it before or after it has reached temp?Really would narrow down the problem with more info.Look inside burner area check for any water sometimes there is a very small drip that lands on top of the burner.If no leak then it's a control valve,air intake or vent issue but need make and model and first 4 on serial #
wctekkk is offline   Reply With Quote
Old 05-31-2012, 11:07 PM   #4
is this a new piece of equipment? Has it always been this way? model, s/n, manufacturer always helps. What do you mean 'the system shuts down'? Does the burner shut off, or the entire unit?
There are intermittent pilot systems out there. They will ignite the pilot, satisfy, run the burner till the call for heat is satisfied, then turn both the pilot and burner off.
Protocol. is offline   Reply With Quote
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 03:54 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
brand new Hot water heater won't stay lit r386 Plumbing 4 08-23-2009 09:31 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
