Anyone Replace An Ignitor For An Electrolux Gas Cooktop? - Appliances - DIY Chatroom Home Improvement Forum
Old 07-15-2014, 05:01 PM   #1
Rewards Points: 37
Anyone replace an ignitor for an Electrolux gas cooktop?
Our rental has the EW36GC55GS and it was working fine until recently when I heard the ignition no longer works but can be lit manually with a lighter as the gas flow was fine. The fuse was not tripped and the outlet it is connected to still works fine so it is definitely the unit itself. Looking closer, it appears that one of the renters got a little happy with our pot filler and the ignition box was full of water (picture below).
I'm guessing that's the cause since the issue is isolated to the cooktop but I cannot find anything online on how to replace the thing to know for sure. Has anyone had any experience with these things and how to replace? Is there a way to check if the damage was confined to the ignitor only?
PDubs is offline   Reply With Quote
Should I replace my Federal Pacific Breaker Panel? scottgriz Electrical 15 11-23-2012 08:09 PM
Original (?) galvanized water supply pipes replace with PEX, CPVC, copper? TomServo Plumbing 5 11-07-2012 12:07 AM
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 09:55 PM
Replace std. oven/range with one without cooktop? denemante Remodeling 2 12-06-2010 08:13 PM
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 03:41 PM
