Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 07-19-2012, 02:06 PM   #1
amana washing machine not draining
Hello, I have an amana washing machine model(nfw7200tw). Its about 3 years old. I was getting a not draining alarm when I washed clothes ..I checked to see if there were any clogs/kinks, I couldn't find any.(I only could disassemble up to the tube just past the drain pump). My local hardware guy told me it had to be the drain pump. I replaced the pump and am still getting a not drain alarm. Is there a diagnostic check I could run and if so how is it done. Or anything else I could do? thanks in advance.
jim433 is offline   Reply With Quote
Old 07-19-2012, 03:25 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
when you had the pump off did you check inside the hose that goes into the pump? what did the pump filter look like?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 07-19-2012, 03:35 PM   #3
yes, i did, it looked clean/nothing in it...i dont think this model has a filter. at least i cant find one.
Old 07-19-2012, 05:55 PM   #4
#1 HAWKEYE FAN
this is a front load machine correct? It should have a filter right before the pump
Old 07-19-2012, 06:34 PM   #5
i cant find a filter there. all it has is another black tube thats clean.
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Vinegar in the Washing machine wraiththe Plumbing 6 01-12-2012 11:51 PM
Washing machine backs up when draining barrsy Plumbing 2 11-28-2011 05:36 PM
Washing Machine Draining Outside redcrawl Plumbing 4 06-12-2011 04:56 PM
Draining washing machine into cleanout mopar383 Plumbing 3 02-27-2011 06:55 PM
