Amana Washer? - Appliances - DIY Chatroom Home Improvement Forum
Old 10-17-2012, 09:25 PM   #1
Amana washer?
I put my washer in storage last year and a guy put antifreeze in it. When i hooked it up it filled up with water but it was running right through the drain hose.
Mallard1123 is offline   Reply With Quote
Old 10-18-2012, 07:08 AM   #2
custom user
Rewards Points: 150
I'm not sure of the question but anti-freeze is a big no no in waste lines.
JasperST is offline   Reply With Quote
Old 10-18-2012, 07:16 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,450
Mallard....just run a couple of cycles through it to make sure it runs correctly.....you might have just seen a short cycle....
Last I heard, anti-freeze was not an issue for waste water...unless you're on a septic system.
ddawg16 is online now   Reply With Quote
Old 10-18-2012, 07:16 AM   #4
I tried to do a load of clothes. The washer tub filled with water but didn't do anything after that except water continuously ran out of the drain hose. It never agitated.
Old 10-18-2012, 07:20 AM   #5
JOATMON
ddawg16's Avatar
How old is the washer?
Old 10-18-2012, 07:21 AM   #6
Rewards Points: 6,652
Stuck draining valve.
Old 10-18-2012, 07:24 AM   #7
Id say about ten years. Where ia the drain valve? Ive work on whirlpool but not amana.
Old 10-18-2012, 07:29 AM   #8
Follow the drain hose. Same place on all machines, underneath.
Old 10-18-2012, 07:32 AM   #9
This is what a drain pump looks like on an amana http://www.repairclinic.com/PartDeta...p/3363394/3296 Cheap plastic, and they wear out. I just had to replace a handle on our Maytag dishwasher, which the handle was nothing but plastic. Fell apart after six years of use.
Old 10-18-2012, 07:51 AM   #10
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
how high is your drain line? If your drain hose is not elevated to at least 34" the water in the tub will just continue to siphon out the drain hose. Is you hose just lying on the ground or is it going into a stand pipe? Easy fix
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 10-18-2012, 08:00 AM   #11
It was lying on the ground. Lol i feel like an idiot i forgot about that. Can i tie the drain line intp sewer pipe 6-7 feet and up from washer?
Old 10-18-2012, 08:02 AM   #12
Yes, there should be no problem.
Old 10-18-2012, 08:03 AM   #13
Ok, what's the best way to tie in? Its a 3" copper pipe.
Front load Amana washer leaking from inside of door! Stephenby Appliances 4 06-10-2012 06:38 PM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
front loading washer LG or Amana twc Appliances 10 04-23-2011 05:10 AM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Amana washer comp Appliances 2 02-09-2010 01:37 PM
