Amana Refrigerator/freezer - Appliances - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 08:30 AM   #1
amana refrigerator/freezer
why is my freezer not cold enough
sdgowan is offline   Reply With Quote
Old 02-12-2012, 08:36 AM   #2
Probably because it's not blowing enough cold air around in the freezer...
jfrotten is offline   Reply With Quote
Old 02-12-2012, 08:39 AM   #3
What do I need to check to fix this problem.
Old 02-12-2012, 08:41 AM   #4
Is the temperature adjusted high enough for starters, are the coils frozen, is the fan running, do you have way too much stuff in the freezer, is it plugged in...
Old 02-12-2012, 09:13 AM   #5
I have changed filter and cleared vents in freezer. Is there a part I need to change.
Old 02-12-2012, 09:17 AM   #6
ok the fan is running. It is plugged in and the vents are cleared. How do I unfreeze the coils.
Old 02-12-2012, 09:24 AM   #7
vent covering fan is covered in dust. Could this be the problem.
Old 02-12-2012, 09:36 AM   #8
If your coils are frozen over then you have a problem with either the defrost thermostat or defrost heater. For now, you can unplug it and melt the ice with a hairdryer. Your fridge will work for about 3 days until it freezes over again. (temporary fix) what's the model?
Old 02-23-2012, 01:23 PM   #9
It's always something
Rewards Points: 150
make sure the fins in the back of the unit are dust-free. Make sure the door is sealing all the way. Does the compressor kick on more frequently than it probably should?
If the coils are frozen over, that usually means it's running too much I believe. Which means your door might not be sealing. If all else fails, call a repairman and maybe he can see if your freon is low.
SingleGuy is offline   Reply With Quote
Amana HVAC System--Any good? kennykenny HVAC 0 07-26-2011 08:47 PM
Amana 2005 condensor paired with 3.5 ton Goodman unit, but I paid for a 4 ton Amana KasB HVAC 4 04-23-2011 03:41 AM
Oven Door question for Amana Gas Range ChrisJJ Appliances 1 09-13-2010 06:48 AM
Rheem vs. Amana fajoza45 HVAC 3 02-19-2010 11:35 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
