Amana Refridge Ice Maker Problem - Appliances - DIY Chatroom Home Improvement Forum
Old 09-11-2007, 08:09 PM   #1
amana refridge ice maker problem
My fridge has decided not to make ice. The drinking water part of it works o.k., so i decided to replace the entire water valve selunoid coil thing in the back and when i did that absolutely no water comes out of the icemaker or drinking water compartment. So I put the old one in again to see what would happen and again nothing works. If the water valve is nothe problem and the selunoid coil is not broken....what else could be the reason it stopped all the sudden? There are no crinks in the line, the screen in the ater valve is clean...any ideas? thanks
dmoney is offline   Reply With Quote
Old 09-13-2007, 08:10 AM   #2
what fridge is it? can you get any wiring diagrams?..hopefully you chose the right coil to check with? it may not be correct and to weak to lift the valve....
when the coil is energised you should be able to hover the end of a small flat screwdriver over it and feel and hear the magnetic pull, which should test the coil...if still no water, then the valve itself is knackerd..try disconecting the water before the coil if possible and quickly to see if you have water there...cheers mitch
fridgeman is offline   Reply With Quote
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 09:02 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
Refrigerator ice maker problem apt238 Appliances 24 09-18-2006 07:53 AM
