Amana Microwave Convection Exp. 208 Volts - Appliances - DIY Chatroom Home Improvement Forum
Old 03-21-2012, 05:59 PM   #1
Amana Microwave Convection Exp. 208 volts
Hello,
I bought a Microwave Oven – Amana Convection Express volts 208 vac/60 hz; freq 2450 mhz; current pwr 4000 watt and plugged in to 240 home supply. It doesn’t work - not even a light bulb. Why? I have been told that it will work fine. Any idea or suggestions
Thank you all
margaret17 is offline   Reply With Quote
Old 03-21-2012, 09:14 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
should work, something is obviously wrong with the microwave or your outlet
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 03-22-2012, 07:55 AM   #3
not exactly - if i had 240 volts appliance it would work on 208 supply but 208 on 240 it maybe too much difference. this oven is made in 1998 and is only for 208 V (3 PHASE) doesn't have that tolerance 208-240.
Old 03-22-2012, 09:39 AM   #4
#1 HAWKEYE FAN
yes, it would still work
Old 03-22-2012, 09:42 AM   #5
#1 HAWKEYE FAN
correction, it will not work if it is a 3 phase microwave
Old 03-22-2012, 11:17 AM   #6
yes this is a 3 Phase microwave by 208 v. my outlet is 240v 3 phase - thus, I think the appliance will not work due to the higher electric waves. Correct me if I'm wrong.
Thanks , Margaret
Old 03-22-2012, 09:32 PM   #7
#1 HAWKEYE FAN
no your 240v should be single phase . it is the phase difference that is making your unit not work, not the voltage difference
Old 03-22-2012, 09:34 PM   #8
of course now all makes sense - thank you so much margaret
Wiring replacement microwave kgreer313 Electrical 2 12-07-2011 11:08 PM
Amana 2005 condensor paired with 3.5 ton Goodman unit, but I paid for a 4 ton Amana KasB HVAC 4 04-23-2011 04:41 AM
over-the-range microwave problem aumanpj Appliances 6 12-04-2010 06:46 PM
Microwave ground prong sparks/melts upon plugging it in microwaveman Electrical 30 05-10-2009 11:30 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
