Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 07-11-2011, 04:53 PM   #1
Amana Gas Range Won't Light
Burners work fine, but about 1 in 15 times we turn on the oven and 30 min later it's still not heated up, maybe up to 145 deg but that's as hot as it gets. The igniter is burning bright but there is no gas sound or smell.
If i turn on a stove top burner while this is happening you can hear the oven light (kind of a woosh sound) and it works fine, i can then turn off the stove top burner and it will work fine all day.
Anybody have any ideas? I would normally think that the igniter is bad but it works 14 our of 15 times perfectly....
linuxrunner is offline   Reply With Quote
Old 07-11-2011, 09:55 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
your ignitor is probably getting weak. turn your oven on and time how long it takes to ignite the burner. Should be around 60 seconds.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
How many wires can be tapped into a light fixture? JayBird Electrical 6 07-11-2011 03:44 PM
Dual-brite motion detector light to operate second light? downunder Electrical 2 09-10-2010 04:48 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
