Air Conditioning - Appliances - DIY Chatroom Home Improvement Forum
Old 07-10-2011, 07:45 PM   #1
air conditioning
my blower on my lennox 80mgf(x) furnace won't run, the compresser will come on when you lower the temp.!
naemicarl is offline   Reply With Quote
Old 07-10-2011, 07:50 PM   #2
Lennox air conditoning
the blower on my furnace that supplys air flow for the air condoning won't run
Old 07-14-2011, 02:00 PM   #3
Rewards Points: 516
Could be motor. Could be a board, especially if multi-speed fan.
Repost under HVAC section for expert replies.
diyorpay is offline   Reply With Quote
Old 07-14-2011, 11:17 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
Do you have a digital meter with mfd capability?
I'd start at the run capacitor. Even if you don't own a meter it is less than $15 for new run cap (you'd need to get the numbers from the old cap first and get the exact same spec'd cap) and it is needed to start the motor so you may get lucky and that be it.
There are sometimes tell tale signs that the capacitor is bad such as it's blown so the top where the electrical prongs are or the bottom would be rounded and curved versus flat as when not blown. Or there could be the gooey, thick, oily, jell substance leaking out of it somewhere. You'd have to inspect it and see.
Make certain you turn the breaker to the blower off before you do anything, not just the thermostat.
This would be the first thing I'd check as it's a pretty common problem as well as the cheapest fix.
The 5uf and minimum 370 volt numbers are what you'd be looking for on yours. Yours might not be a 5uf but you get the idea. Like for like.
Let us know.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
me1900 (07-14-2011)
Air conditioning ducts trempymom HVAC 0 05-30-2011 11:06 AM
Easy Water conditioning system Pstein Plumbing 4 08-29-2010 07:29 AM
furnace and air conditioning package price MichaelV HVAC 3 12-02-2008 08:19 AM
Microwave Fan Turns on Air Conditioning - help please Littledj HVAC 16 07-03-2008 08:23 AM
Bryant Air Conditioning Unit ARTLEE HVAC 1 07-01-2007 07:22 AM
