Adjusting Flame On Stove - Appliances - DIY Chatroom Home Improvement Forum
Old 10-23-2008, 12:08 AM   #1
Adjusting flame on stove
How do you adjust the flame on a gas stove? I have one burner, that even when turned to the lowest setting, is still high enough to keep liquids at a rolling boil. It is set higher than the rest. Any help would be greatly appreciated.
mamakin5 is offline   Reply With Quote
Old 12-01-2008, 09:44 PM   #2
On some of the gas burner valves you pull off the handle and there is an adjustment screw in the middle of the shaft of the valve. Turn to adjust.
hoistdoctor is offline   Reply With Quote
Old 12-05-2008, 04:48 PM   #3
Thanks so much for your help with this. I tried it and it worked perfectly!
comfortmaker flame sensor big ron Appliances 1 11-02-2007 09:20 AM
Flame blowin' in the wind... testeng HVAC 4 10-28-2007 03:11 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 05:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
