-   -   Adjusting flame on stove (http://www.diychatroom.com/f47/adjusting-flame-stove-30467/)
mamakin5 10-23-2008 12:08 AM
How do you adjust the flame on a gas stove? I have one burner, that even when turned to the lowest setting, is still high enough to keep liquids at a rolling boil. It is set higher than the rest. Any help would be greatly appreciated.
hoistdoctor 12-01-2008 09:44 PM
On some of the gas burner valves you pull off the handle and there is an adjustment screw in the middle of the shaft of the valve. Turn to adjust.
mamakin5 12-05-2008 04:48 PM
Thanks so much for your help with this. I tried it and it worked perfectly!
