Ac Window Unit Circut Keeps Tripping - Appliances - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 02:18 PM   #1
ac window unit circut keeps tripping
my window unit AC keeps tripping i have cleaned filter checked drain and reset and it still tripps
MrsG is offline   Reply With Quote
Old 09-23-2010, 02:58 PM   #2
What size breaker & wire ?
What size AC, how much power does it pull ? watts...amps ?
Old 09-23-2010, 04:01 PM   #3
Rewards Points: 468
window ac unit trip's breaker
did it ever work ok at this install place?? And now it is tripping breaker?? Is it on a dedicated circut. Which is the only thing on that line ? A little more information is needed
del schisler is offline   Reply With Quote
Old 09-23-2010, 06:12 PM   #4
Rewards Points: 150
AC should have its own line to the breaker. How many amp does the AC charges? You might have to change breaker to higher amp. Check all details first. It's more of electrical problem than the unit itself.
MagicalHome is offline   Reply With Quote
Old 09-23-2010, 09:30 PM   #5
HVAC / Plumbing
don't change breaker to higher amp Without checking wire size
kenmac is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Need help w/squealing screeching ac window unit ohiogirl HVAC 1 07-12-2009 07:01 PM
Nasty smell in my Samsung window unit deejohnson HVAC 4 06-15-2009 10:02 PM
Adding Geothermal heat exchanger to window unit richinok HVAC 4 06-23-2008 07:59 PM
Window AC unit problems, Please assist if you can! Boscy HVAC 1 07-28-2005 11:58 PM
