5000 BTU Window Unit - Appliances - DIY Chatroom Home Improvement Forum
Old 04-30-2013, 10:54 AM   #1
Rewards Points: 27
5000 BTU Window unit
I have a window air conditioner, 5000 btu, that is not blowing air as cool as it should. Can these be recharged?
ROBBYT3 is offline   Reply With Quote
Old 04-30-2013, 12:16 PM   #2
Rewards Points: 760
Look at other things first. Are the evaporator and condenser clean? Is the filter clean? Is the fan running at the right speed.
It's usually not worth it to charge it and there are a few problems doing it.
The system usually only holds a very small amount of refrigerant. Just connecting the gauge set can cause you to lose some charge. Most don't even have charging ports.
Replace it. A newer model will be more efficient anyways.
AandPDan is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Need help w/squealing screeching ac window unit ohiogirl HVAC 1 07-12-2009 06:01 PM
Nasty smell in my Samsung window unit deejohnson HVAC 4 06-15-2009 09:02 PM
Portable A/C unit + Swinging Window alpha202ej HVAC 1 07-18-2008 10:51 AM
Adding Geothermal heat exchanger to window unit richinok HVAC 4 06-23-2008 06:59 PM
