50 Gal Water Heater, 10-15 Min Shower? - Appliances - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 11:47 AM   #1
Trucon01's Avatar
Rewards Points: 510
50 Gal water heater, 10-15 min shower?
Hi All,
I do not have the specs handy, but thought I was ask first. I have a 50 gal GE water heater in a house that I just bought (old construction).
When we take a shower, the hot water is gone in about 10-15 min with only 1 shower going. The shower head is one of those rain like heads that comes with a hand wand and has 6 jets on the metal unit hanging on the wall.
Is this just a junk water heater or are we using all 50 gallons?
Trucon01 is offline   Reply With Quote
Old 01-12-2012, 11:56 AM   #2
Grab a 5-gallon bucket and a watch, and in 10-15 minutes you'll know your answer.
Minich is offline   Reply With Quote
Old 01-12-2012, 12:02 PM   #3
Trucon01's Avatar
Rewards Points: 510
If it has a low first hour number, should I just get a much better 50 gal or should I just get one of those Marathon 105 gal units from HD?
Old 01-12-2012, 12:10 PM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Trucon01 View Post
I have a 50 gal GE water heater in a house that I just bought...
I do not have the specs handy.
Some specs to get:
what sort of water quality do you have (minerals etc) ?
what is the raw water pressure to the house like (PSI)?
what is incoming water temp?
what is outgoing water temp?
what is the flow rate (GPM) through the shower head?
what temp water = "hot shower"?
how old is the WH?
has it EVER been serviced (flushed)?
Old 01-12-2012, 12:16 PM   #5
Trucon01's Avatar
Rewards Points: 510
Great. I'll get those tonight and post in the morning.
Old 01-12-2012, 12:45 PM   #6
Is it a double element electric water heater by any chance?
jfrotten is offline   Reply With Quote
Old 01-12-2012, 12:47 PM   #7
Rewards Points: 13,450
That would have been my first guess, one of the elements is blown.
Old 01-12-2012, 03:46 PM   #8
Retired
Edgar214's Avatar
If the water heater has some age the dip tube could be cracked and/or broken. This doesn't allow the cold water to go to the bottom of the tank to be heated.
Mike
THE ONLY THING THAT'S CONSTANT IS CHANGE
Edgar214 is offline   Reply With Quote
Old 01-12-2012, 07:07 PM   #9
Furd's Avatar
A tank-type water heater will only supply about 70% of its rated volume (about 35 gallons in your case) before a significant drop in the output temperature occurs.
You can effectively increase the amount of hot water by raising the temperature of the tank and then blend in more cold water at the point of use. The downside to this is that you significantly increase the risk of being scalded by the straight hot water and it will cost more to heat the water. Installing a tempering valve (which mixes cold water with the hot as soon as it leaves the tank can reduce the risk of scalding while increasing the effective amount of hot water but the increased cost of operation will remain.
Furd is offline   Reply With Quote
Old 01-12-2012, 07:10 PM   #10
Trucon01's Avatar
Rewards Points: 510
This is the water heater I have:
http://m.geappliances.com/GEApplianc...Sku=GE50M06AAG
Old 01-12-2012, 08:56 PM   #11
Trucon01's Avatar
Rewards Points: 510
So I just checked the temp settings (There are 2, top and bottom). The top was set at 125 and the bottom was set about 5-10 degrees lower. I just set them both to around 130, so we will see what happens.
Old 01-12-2012, 09:29 PM   #12
Msradell's Avatar
Rewards Points: 172
My guess would be that with all those heads you're probably using all the water in that length of time.
Msradell is offline   Reply With Quote
Old 01-12-2012, 09:37 PM   #13
Trucon01's Avatar
Rewards Points: 510
No, we have 3.5 bathrooms and its just my fiance and I. And ever since we bought the house in April, we've only used the one shower in the house, never 2 at a time. I'll see what the temp change does. If all else fails, we are remodeling the basement and I will just put in one of these bad boys, 105 gallon.
http://www.homedepot.com/Plumbing-Wa...kuId=202894352
Old 01-13-2012, 08:11 AM   #14
Shut off the power, remove the wires to both elements and check for continuity. You should have continuity between the two screws on each element and you should not have continuity between any one screw and the tank itself. If any of these things do happen, you have a bad element. My guess is that your bottom element is bad our your water temp was just set too low...
Old 01-13-2012, 09:47 AM   #15
Trucon01's Avatar
Rewards Points: 510
I truly appreciate everyone's help thus far!! This morning for the shower, I noticed that I didn't have to turn the nob as far towards hot to take a shower. Maybe just turning the temp up on both elements did the trick... Thanks again for taking the time to help me!!!
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Need opinions. RO filter to water heater to shower unandrunning Plumbing 7 06-22-2011 04:00 PM
Hot Water Heater Help--New Home! HeatherJ Plumbing 12 04-25-2011 02:53 PM
